Ford 3000 tractor telescoping lift arms
   / Ford 3000 tractor telescoping lift arms #1
steve's3000
1971 Ford 3000
Hello, has anyone replaced there non-teloscoping lift arms with telescoping lift arms on their 3 pt. for a 1971 Ford 3000 tractor. If so what part number or what tractor telescoping lift arms will work. It is really cumbersome to cool up a heavy 3 pt. attachment.
It looks like just maybe the arms off a Kioti ck2610, ck3510 may work. They are also 31" long but not sure of angles at the ends and thickness of the arms. Mine are 1/2" thick. The Kioti may be 3/4" thick.
Thank you
   / Ford 3000 tractor telescoping lift arms #2
I haven’t, but the extendable 3 point arms on my TC45DA are the best thing ever IMHO. 😎
I want to add a set to my IH 424 if I keep it as they make hooking up 3 point equipment a very non-strain full event.
   / Ford 3000 tractor telescoping lift arms #3
Best thing ever until someone came up with a quick hitch. 🤣
   / Ford 3000 tractor telescoping lift arms #5
Or a Pat's easy hitch which is probably easier and cheaper to install
   / Ford 3000 tractor telescoping lift arms #6
Mine was $89 as I recall. What's yours? And I don't have to get off my tractor to attach most implements. Grab and go for everything that doesn't need a PTO connection. Pat's doesn't include the top link. How do you deal with that "quickly"?
How long are they on the TC45DA? How thick are they?
   / Ford 3000 tractor telescoping lift arms #9
They are about 34” overall length, the arms are about 2 3/8” deep (top to bottom) and about 13/16” wide.
   / Ford 3000 tractor telescoping lift arms #10
I haven’t found a source for moderately priced “generic” extendable link arms. When I was considering switching my two tractors with standard arms the best I could find was through the OEM and they were outrageously priced.
I ended up welding euro hooks on. They’re heavier duty than the Pats system, but you will need a welder.
I have another tractor with extendable links and I prefer the hooks, but it’s not so bad that I’m in a hurry to switch that tractor too.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
