Price Check Ford 3000 $?
/ Ford 3000 $? #1
Loadstar
Platinum Member
Evansville, IN
Ford 640
Went out and picked up some concrete culvert pipe the other day. It was at a large local industrial contractors yard that my father in law works at. I wandered around a bit and found a small ford tractor with duals. I asked him if they would sell it because you could tell it wasn't worked and there were much newer tractors around. Couple weeks later he told me they were interested in selling it.
I believe it is a ford 300 diesel. They take decent care of equipment mechanically. Sheet metal is beat up pretty good but I don't care. I am hunting for a hill mower/woods mower. I usually use tractor house as a bluebook ballpark but they are scattered. Wondering what others thought on an offer?
/ Ford 3000 $? #2
Hour meter?
i don't have a clue what to tell you, but the hours would help. Wonder if you could demo it for a day? Just to make sure everythings working right.
/ Ford 3000 $?
I think the hour meter read 550ish. Not sure if it works. I'm glad I'm not the only one in the fog about an offer haha. Just stinks because it's the size I need, beat up which is what I desire, and it has duals. I never looked it over real hard because I did not really expect them to show interest in selling. I am going to return to really go over it. Just not familiar with this machine and thought I would go fishing for some thoughts.
/ Ford 3000 $? #4
there are quite a few ford 3000 owners on here. If you don't get much of a response in the next day or two, post under the Buying/Pricing category. Big bold letters FORD 3000?
Should get some good ideas where to look for potential problems. but I think that is a nice overall tractor.
/ Ford 3000 $?
10-4. I hope to get more info soon and like you said maybe talk in a demo. I might not get to take it home but the yard there is huge with implements around and plenty of obstacle course.
/ Ford 3000 $? #6
Does it have power steering?hard to price it without looking it over but with the sheet metal beat up around my area $1500-$3500 tops if it's mech.sound with usable tires.my 3000 is one of the better tractors that I have owned. Hope this helps,good luck.
/ Ford 3000 $? #7
Tires can get expensive, brakes? how well do the heel brakes work, and how easy/hard is it to fix them. That type of stuff jumps out at me when I look at older stuff.
/ Ford 3000 $?
Good stuff, I'm making a list of things to check. Most interested in pulling oil plugs. Good idea about brakes. Also tires have been on my mind too as I said I didn't look too hard.
/ Ford 3000 $? #9
what trans and pto type? 8spd with a dual clutch is prefered. 6spd with dual is more rare, 6spd single is more common.. and 4spd single is most common/basic.. usually you see the latter on 2000's not 3000's
check cam box on IP.. if low on oil, or mostly fuel comes out.. it hasn't been well servi ed.
check oil for water.. water for oil.
check trans sump and rear/hyd sump for water emulsion.
check pto shaft to see if it has in / out movement.
steering? manual or ps.. any play?
tires?
start ok cold?
dash indicators for charge and oil pres work.. key on = red lamps.. after start oil lamp goes out and hopefully genny lamp too.
leaks?
3pt work?
post back
good running 3 cyls in that size range go from 2500-4500$ depending upon options and condition.
/ Ford 3000 $? #10
Soundguy really knows how to kill a thread:laughing: How can anybody add anything to what he just said:thumbsup:
Post us some pics when you go take a look at it agian.
/ Ford 3000 $?
I will update as soon as I am updated haha. Next week may be the earliest I have time to check it out. Will add pictures if I can when I get them.
I'm a little murky on checking the oil on the cam box on the injector pump but I will familiarize myself with that. Also the dual clutch option. I do not know much about these because I have not owned one, but that's nothing I can't get over with a manual, lots of staring, and a cold beer.
/ Ford 3000 $? #12
the ip will have chek level plug onit.
the trans/pto
first see if it is a twin or single stick.
if single.. shes a non live 4.
if twin.. 6 or 8
both could be live.
read model id on bellhousing and post it...
/ Ford 3000 $?
Live would be nice but that's just a luxury to me. I do hope it's a six or 8 the additional gears would be nice. I'm mainly after the additional traction and hp. This tractor will be left at the family's vacation home for primarily big hill mowing. It is a remote area which is the main reason I am looking for a rough looking tractor. I don't want anyone taking a liking to it before I have a barn there.
/ Ford 3000 $? #14
even if a 4 spd.. she'll mow just fine...
/ Ford 3000 $? #15
Duals? Odd. Is it a low profile? If so, you can probably get it for a song as few folks will want it though it would make a great mowing tractor for steep areas.
Aside from the obvious, the value will depend mostly upon the transmission. As Soundguy says, the 4X2 transmission is most desired by most folks. Pass if it is the basic 4 speed, as these are geared much too fast and cannot have live PTO. If a S-O-S, you can also probably get it for a song as many folks are afraid of these, though the late models S-O-S as used on post 64 tractors such as this is just about bullet proof so long as it has had even infrequent oil/filter changes.
Contractor? Look for evidence of FEL use. The 3000 front axle is not designed for heavy FEL use.
More info with picture.
SDT
/ Ford 3000 $? #16
i've seen duals on gold course mowers.. Low profile too..
/ Ford 3000 $?
Checked it out again and it has live PTO,8 spd, power steering. 497 hrs shown.
/ Ford 3000 $? #18
looks like a nice project
/ Ford 3000 $?
Sounds pathetic but I felt like I was driving a Steiger! Fun little tractor. It took a while to start dead battery. But once she got to cranking it started right up smoke cleared up after couple min and really just smoked on throttle crams. Now if only I knew what to offer I'm in love with that thing but I better not let it show.
/ Ford 3000 $? #20
if it smokes a lil on throttle, it MIGHT clear up after rings are good and moving.. however.. I bet it's a lil loose in the top end.
no real biggie..
and if it's black smoke.. that's normal on a NA diesel..
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2014 TEREX USA LLC LIGHT TOWER (A60736)
2014 TEREX USA LLC...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2025 Pabreak 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
