Price Check Ford 3000 $?
/ Ford 3000 $? #41
Yes.
The remote valves like the AICO dual spool valve pictured (and other more common valves) that fit 55 - 64 Ford tractors will also fit the 3000. TISCO still sells both single spool and dual spool valves and complete kits for these tractors but they are not inexpensive.
SDT
/ Ford 3000 $? #42
May have been a bushhogging mowing tractor. If a mowing tractor expect a lot of wear on a couple gears unually 4th low range and 5 th high range, Expect lift wear and clutch wear. Take a close look at the lift arm attachment balls at both ends are they worn? Hour meter is not important.
Ifs its needing fixing just how much are you willing to spend on it? to patch it?
The english fords are too popular for a good one to for 2000 thats more in line with an N
/ Ford 3000 $? #43
/ Ford 3000 $?
$2,500 plus sales tax so $2,650 was the news tonight.
/ Ford 3000 $? #45
even cheaper than the beater 3000 i bought with bad battery, starter, genny, and near non existant brakes and some cobbled welded parts.. ;)
2025 JBD 32in. Hydraulic Mixing Bucket Mini Skid Steer Attachment (A61567)
2025 JBD 32in...
CATERPILLAR FORKLIFT GP25 (A60736)
CATERPILLAR...
2003 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2003 V.E...
2004 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2004 V.E...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
