Ford 4000 Questions
   / Ford 4000 Questions #1
TBigLug
Bronze Member
Stockbridge, MI
John Deere 401C
1964 Ford 4000 (841), 4 sp. Couple questions.
1. What is the procedure for adjusting the brakes? They work but barely and only right before the pedal hits the floor.
2. What could cause a no first gear issue? Tractor was like this when I bought it. It doesn't grind or anything, shifts into the slot like a normal gear. Let off the clutch, nothing there. I don't have a concrete floor so I don't think I can split the tractor and get it back together. Anyone ever seen a problem like this or have a diagram of the transmission? I'm hoping it may be a busted pin or some such.
Thanks for the help.
   / Ford 4000 Questions #2
Go to CNH parts online website. They have great pictorial parts diagrams showing all parts involved.
In this case I looked for the brake linkage parts to figure out how to adjust the brakes.
See Part # 27 & 28. They show the linkage rod and clevis that are adjustable to get "good pedal".
I have no clue in regards to the trans problem. But again this website may offer pictorials of the trans setup that might give you a clue.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
   / Ford 4000 Questions #3
Adjust the brakes through a slot in each backing plate via an adjuster with a star wheel as you would a typical drum & shoe brake. Use the external rod and clevis adjustments to balance the pedals after adjusting the star wheel.
   / Ford 4000 Questions #4
Good stuff Rick!!!!
I was so wrapped up in the linkage adjustment that I forgot to send him there first.
Again, on the CNH parts website there's a very good picture of the wheel brake assembly, including the adjusters.
Awesome, I ended up getting the brakes adjusted. No rod and clevis for my pedals, just bolted to a shaft. I'll look into the parts diagrams for trans ideas next. Thanks.
   / Ford 4000 Questions #6
I first remove the clevispin from the brakelinks. Then adjust the brakes to lock wheels then unscrew starnut till wheels come loose.
Then I adjust that clevis and rods til pedals is equal.
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2017 CATERPILLAR 420F2 IT BACKHOE (A60429)
2017 CATERPILLAR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
24220 (A56859)
24220 (A56859)
