Ford 555 backhoe leaking transmission oil ????
   / Ford 555 backhoe leaking transmission oil ???? #1
lynn_florida
I was using my 555 backhoe today it has tranny with no clutch just forward and reverse lever. It started leaking oil out of access plate on tranny . The one with 4 bolts and plate comes off and you can see torque converter. Any ideas is it dead and how complicated to repair any suggestions will be helpful. /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #3
Sounds like the converter seal. Tractor may need splitting, and seal replaced. /forums/images/graemlins/frown.gif
   / Ford 555 backhoe leaking transmission oil ???? #4
Do you think there will be a pump problem tractor had set for a while or just a bad seal ??? /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #7
You won't really know until you either investigate futher, or split the tractor, and inspect the seal. You really nedd a Ford 555 expert to help you out here.
   / Ford 555 backhoe leaking transmission oil ???? #8
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Fire Truck (A51692)
Fire Truck (A51692)
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
2008 FORD F-350 (A52472)
2008 FORD F-350...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
