Ford 555 backhoe leaking transmission oil ????
   / Ford 555 backhoe leaking transmission oil ???? #1
lynn_florida
I was using my 555 backhoe today it has tranny with no clutch just forward and reverse lever. It started leaking oil out of access plate on tranny . The one with 4 bolts and plate comes off and you can see torque converter. Any ideas is it dead and how complicated to repair any suggestions will be helpful. /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #3
Sounds like the converter seal. Tractor may need splitting, and seal replaced. /forums/images/graemlins/frown.gif
   / Ford 555 backhoe leaking transmission oil ???? #4
Do you think there will be a pump problem tractor had set for a while or just a bad seal ??? /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #7
You won't really know until you either investigate futher, or split the tractor, and inspect the seal. You really nedd a Ford 555 expert to help you out here.
   / Ford 555 backhoe leaking transmission oil ???? #8
Giyi Excavator Pallet Forks (A57149)
Giyi Excavator...
Aluminum Mermaid (A57454)
Aluminum Mermaid...
2008 Mercury Milan Sedan (A56859)
2008 Mercury Milan...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2-5TH WHEEL PLATES (A58216)
2-5TH WHEEL PLATES...
