Ford 555 backhoe leaking transmission oil ????
   / Ford 555 backhoe leaking transmission oil ???? #1
lynn_florida
I was using my 555 backhoe today it has tranny with no clutch just forward and reverse lever. It started leaking oil out of access plate on tranny . The one with 4 bolts and plate comes off and you can see torque converter. Any ideas is it dead and how complicated to repair any suggestions will be helpful. /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #3
Sounds like the converter seal. Tractor may need splitting, and seal replaced. /forums/images/graemlins/frown.gif
   / Ford 555 backhoe leaking transmission oil ???? #4
Do you think there will be a pump problem tractor had set for a while or just a bad seal ??? /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #7
You won't really know until you either investigate futher, or split the tractor, and inspect the seal. You really nedd a Ford 555 expert to help you out here.
   / Ford 555 backhoe leaking transmission oil ???? #8
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2007 National RV Dolphin Class A Motorhome (A51694)
2007 National RV...
