Ford 555 backhoe leaking transmission oil ????
   / Ford 555 backhoe leaking transmission oil ???? #1
lynn_florida
I was using my 555 backhoe today it has tranny with no clutch just forward and reverse lever. It started leaking oil out of access plate on tranny . The one with 4 bolts and plate comes off and you can see torque converter. Any ideas is it dead and how complicated to repair any suggestions will be helpful. /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #3
Sounds like the converter seal. Tractor may need splitting, and seal replaced. /forums/images/graemlins/frown.gif
   / Ford 555 backhoe leaking transmission oil ???? #4
Do you think there will be a pump problem tractor had set for a while or just a bad seal ??? /forums/images/graemlins/confused.gif
   / Ford 555 backhoe leaking transmission oil ???? #7
You won't really know until you either investigate futher, or split the tractor, and inspect the seal. You really nedd a Ford 555 expert to help you out here.
   / Ford 555 backhoe leaking transmission oil ???? #8
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
DRILLING CABINET (A52472)
DRILLING CABINET...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
