Ford 5610 rear stabilizer bar help
   / Ford 5610 rear stabilizer bar help
So does this include both right and left sides? Reason I ask is that most of the ads on eBay are for one side or the other for the same price.
Also I’ve attached a picture of the stabilizer on my 2810. The connection point in center of the picture where the stabilizer and lift arm connect is where I had issues on my 4610. Can’t Remember what the exact issue was but will go back to check soon. So the angle of the stabilizer arm looks to be important which appears to require the extra bracket so as to be mounted closer to the wheels than the rops mount correct?
   / Ford 5610 rear stabilizer bar help #22
Looks like one side to me and I don't see the bracket in the picture. I'd call them to check and see if it's included or not.
I agree. At least now I’m headed in the right direction. Thanks guys
   / Ford 5610 rear stabilizer bar help #24
I honestly can't remember concerning the cost. I do remember mine was a kit including the brackets and hardware.
Yes, the axle bracket is outside the ROPS bracket. If you look at my pics you can see it's mounted as outward as possible.
Mine work very, very well.
Hey that may work. Will call them tomorrow. Thanks
Got’er done. System works great and I love it. Thanks for everyone’s help. IMG_4698.JPG
   / Ford 5610 rear stabilizer bar help #30
Yep, looks lile it belongs there!!! Dramatic improvement and worth whatever the cost if you use your 3pt!!!
The only thing I noticed is the holes are slightly undersized for the pin to go into easily and the inner and outer square tubing bind a bit at times but I’m hoping just because it’s new and that it will break in and improve. Seems already a little better now. Great product though and is a very beneficial option.
   / Ford 5610 rear stabilizer bar help #32
You will like those sawtooth. I put them on my 4610SU. New Holland uses a similar system on my Workmaster that incorporates a round stabilizer bar with adjustment holes and pins. Both systems are a big improvement on the older straight bar stabilizer system. My 1720 utilized a turnbuckle adjustment system. It was good. This newer system is much better IMHO.
   / Ford 5610 rear stabilizer bar help #33
I bought a pair of the aftermarket stabilizers off eBay,they work fine, but are nowhere near as robust as oem. I kept my eyes open and eventually found a pair of oem.
I agree the aftermarket are not the quality of OEM ones but they are close. Way better than old stabilizer bars too
   / Ford 5610 rear stabilizer bar help #35
I noticed the same problems that you mentioned. But as time goes along mine get easier to pin. With minimal effort you can pin your 3pt completely rigid. Only slack being in the various connection points. And it can all be done with no tools and no change during use.
I built a pair for my little JD because it had turnbuckles.
Some CUT and Utility class tractors can still be bought new with chains or turnbuckles...... :(
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
(39) FLOOR TRUSSES (A60432)
(39) FLOOR TRUSSES...
