ford 6600
   / ford 6600 #1
trickyricky
veneta oregon
ford 6600
hey tractor fans,
i just purchased this diesel 6600 and am having trouble getting it to start.
it wants to fire some but just will not run. it ran a week ago when i the guy delivered it. yes first tractor and much to learn.
   / ford 6600 #3
Welcome aboard. At the top of this page, you will find the SEARCH section. Type in Ford 6600 and you will find some posts in regards to your make and model. Good Luck.
   / ford 6600 #4
When starting this tractor you need to push in the cold start button on the fuel pump after putting the throtle at half.
Turn the Key back wards and hold for 20 seconds
This will heat the fuel in the and air in the engine intake.
Then turn the key to start.
Should fire. this will not need to be if the day is reasonable warm, spring or summer.
   / ford 6600 #5
1. Fuel in tank?
2. Fuel turned on? It's possible someone turned the vale under the tank off, not likely, but check everything...)
3. How cold is it? Are you running the preheater (holding the key in the warm-up postion several seconds) and are you flooring the accelerator for max fuel?
4. What shape is the battery & starter in, diesel needs a pretty fast spin to fire up, weak battery can prevent it from starting.
5. Often diesel with a weak battery, slow starter, or in cold temps is hard to start the first time if it sat a day or 2. It will start well the rest of the day. They like full fuel flow until they fireup, floor it.
As well, you may or may not have the little push in button on the injector pump. This is a cold starting aid, and _Really_ works well. Is the injector pump a flat in-line one? Where the throttle cable attaches, there is a little tiny pin sticking out, you can push it in - it should have a tiny rubber boot on it, many are lissing by now. If you have the kill knob 'on' and the throttle about 1/2 or more open, you can push this little pin in and it will stay in - only moves in a 1/4 inch or so. It dumps extra fuel into the system during starting. Not every Ford has this, can't remember what type a 6600 has.... Will help you.
There can be worse, $$$ problems causing a poor start, but I'd look to you just not being familiar with starting diesel, a weak starter or battery, or it being cold and you're not using the cold-start features before looking for the 'engine is worn out' issues.....
--->Paul
   / ford 6600
the manual shows a 4 position key switch ...left 2 spots for heat but i cant get the key to turn to the left. also i didnt see any cold start button on the pump. i will take a closer look. thank you
   / ford 6600 #7
My TW-20 & 7700 have the inline pump and the cold-start button. It looks like a little shaft sticking out is all. The key has off, run, heat, and start for the positions, have to hold it in the heat selection for 1/2 minute or so. The TW will start at 40 degrees or above; rgw 7700 will start around 28 degrees or so. Below that, plug it in for a while..... Be careful using ether if they have the typical Ford pre-heater, as it can ignite the ether in the intake manifold, not good....
My 5200 has the rotary pump, no button, and while the manual talks abot the termostart, it was an option and does not have it. Kinda too bad for me in Minnesota and all. This tractor was very hard to start when I got it. Would fire up fine later in the day, but when it sat overnite or longer would not start easy. I replaced the starter, and it is a world of difference. It had a new battery when I bought it. I also replaced one of the batt cables, as it was poor. Mad a world of difference. I asically needed a shot of ether every day; now I only need the ether or plugging it in below 40 degrees.
--->Paul
Toro Turf Reel Mower (A57149)
Toro Turf Reel...
KBH 25T Tender (A56438)
KBH 25T Tender...
LOT: Steel File Cabinets, Steel Cabinets, Primo Electric Water Cooler (A59076)
LOT: Steel File...
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
