Ford 7710
   / Ford 7710 #11
I am glad to hear it started right up for you. Hopefully things will all be in good shape.
   / Ford 7710 #12
TexasDefender said:
All in all I am REAL excited. As you can tell I couldn't have gotten away with a smaller trailer.
I think you have a lot to be happy with. With any luck, you'll have a really nice cabbed tractor. Are you gonna call it "Ol' 758"?
Just for fun, you should crank up the sweeper and do your driveway just because you can.:D
   / Ford 7710
I did turn the sweeper on just to see if it worked and it did :cool: When we picked it up it was raining so we didn't get a chance to go over everything. I messed with it last night and suprisingly the a/c works VERY well.
I am planning on blue/white to make it look like a ford.
Anybody know where I might get a user's manual?
   / Ford 7710 #14
Id check w/ your local NH dealer first. I bet though he'll sell you a photocopied version. Thats OK unless you want to see details in the pics, then all bets are off. Places like ebay and what not usually have old original manuals for farm equipment. Id do a net search and see what turns up.
ETA: Is the sweeper staying on the tractor? If off are you keeping it or selling?
   / Ford 7710 #15
As Jimg said, Ebay is most likely the easiest place to find them but generally you find more for the 7710-II then the 7710. I bought mine off of Ebay as well as quite a few other hard to find manuals.
   / Ford 7710
Thanks, I'll check out ebay. I found a service manual online that I downloaded, I'm sure it'll help later on.
I plan on doing a little tlc on the sweeper then selling it to cover costs on other implements.
   / Ford 7710 #17
Try amazon as well.. I've gotten a couple manuals from them / used books section..e tc.
soundguy
   / Ford 7710
I've got a few questions after working on it for a few days.
Where should I be able to find the serial number? I'm trying to figure out what year it is.
I'm replacing the interior with the kit from K & M Manufacturing - Your source for tractor seats & accessories. which is going to look great. One problem I have right now is there is a bunch of left over adhesive/foam from the old stuff that is pretty much caked on. I talked to a guy at k and m, he said use a wire brush. I was wondering if someone knew of a solvent or something I might be able to use to loosen up the adhesive?
I've changed out all of the fluids, replaced filters, and removed the sweeper. Everything so far has been pretty easy...except removing the seat, that thing had to weigh about 150#...wasn't very fun by myself.
   / Ford 7710 #19
Robert_in_NY said:
The first thing you should do is take it to a New Holland dealer and have them go over the entire tractor and put it on a dyno. Make sure everything is up to specs and have them inspect everything.
Ha..Ha and have them tell you it's the wrong colour and a little rusty.....You could buy a lot of parts with what they will charge..?
Fantastic tractor...One of fords best .
   / Ford 7710 #20
An hour of dyno time is a good investment at normal shop rates. We aren't talking about a 'walk around' visual inspection.
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
Bucket Truck (A59230)
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
3 Point Attachment (A57454)
3 Point Attachment...
40' CONTAINER (A52706)
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
