Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #371
You probably should run a compression test before we go farther
Will do. Hopefully picking up the tool today from my coworker. I also brought the new alternator with me so I can get it tested at the auto parts store. Hopefully if it is faulty they will just swap it out.
Got the compression tools. Will let you know how it goes.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #374
Mention of lean and the response when adjusting carbureator valve jets might warrant a check on manifold gasket or crack??:confused:
From an old saying you might want to check the rad cap!:(
Well, I think I know what is wrong with the alternator. It is a 3 wire. The previous *non-working* alternator was a 3 wire as well -- just hooked up as a 1 wire. So I guess Since I bought the tractor in July the battery was never charging while it was running. Looks like I get to wire this up now and at least I will get lower RPM charging.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #376
So the old alt may have been ok.
Yeah :mad:
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #378
while it's rare to see a non rebuildable carb.. i did have one on a 600 that i rebuilt 3 times.. would not run right.. put a different one on and it was fine.
not that I'm saying yours is ready for that..e tc...
the sputering is puzzeling.
hold a piece of paper to the tailpipe when it is running and see if it sucks it up to the tail pipe.
also try that tug of choke at sputter
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #379
paper to the tailpipe when it is running and see if it sucks it up to the tail pipe?
SG what would that mean? bad valves?
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #380
yep.. exhaust particularly.. likely burnt.. etc
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
1974 John Deere 6030 Tractor (A55315)
1974 John Deere...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
RoGator RG1100C (A55315)
RoGator RG1100C...
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
