ford commander 6000
   / ford commander 6000 #1
shellman5801
chesterfield va
ford commander 6000
I just purchased a ford commander 6000, The rear tires are locked and will not turn unless you lift the front end and rotate the tractor?? then they rotate freely. I did read about the tractors having lots of transmission issues. Can someone lead me in the right direction in troubleshooting this? Clutch? Shift cable stuck in park? help ??
   / ford commander 6000 #2
The shift cable is unlikely but is also the easiest to check out. After that you are into serious problems especially if this had the 10 speed select-o-matic or whatever that nightmare was called. Did the thing behave OK when before you bought it ? Did something happen while operating it ? It would be helpful to describe the condition of the transmission fluid; pull the dipstick, look at the oil, smell it.
Hope that Rick B chimes in on this one.
This site is great with info, I was told the the tractor rear tires will not move unless the engine is running, That's the best news I have got so far :) I am learning as I go and I see there is alot to learn. Thanks for your reply fishheadbob
got the old girl started today, The next challenge, Will it move ??
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
iDrive TDS-2010H...
iDrive TDS-2010H...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
