Ford Excursion - I think I must have one! Comments welcome.
   / Ford Excursion - I think I must have one! Comments welcome.
I found a 2005 with 90K miles for $15K. Limited 4wd V-10
D.
   / Ford Excursion - I think I must have one! Comments welcome. #52
D.
Make sure it has a good axle and ratio in it. When I was looking for a V-10 powered Excursion last November through about April to replace my 1/2 ton pickup I had a hard time finding one with limited slip for some reason. You can tell by looking on the drivers door pillar. You can google the code to find out if its limited slip and if its 3.55/3.73/or 4.10 If you can not find it I have all the codes. Just post it or PM me. 99% of the time a Ford truck will have a two digit axle code and if its numerical only its NOT limited slip. If it has a letter then a number its limited slip.
Chris
Chris
Ah...it has a code 31. 3.73 non-limited slip. Is that a big deal if it is a 4wd?
D.
What constitutes a towing package on an Excursion?
D.
   / Ford Excursion - I think I must have one! Comments welcome. #55
Cool stuff - I will check that link out.
Thanks,
D.
Man, the torque comes on really early with the diesel. I am still thinking V-10... Heck, I am at almost sea level. If I was up in the mountains - the turbo diesel is probably a no brainer.
I wonder if I could put a 5.9 Cummins in there...
D.
   / Ford Excursion - I think I must have one! Comments welcome. #59
D.
No, because after 50-75K the Ford limited slip is shot anyway. You have to replace the clutch packs to get it working like is was when it was new.
The Ford limited slip is not a real stout locker. Don't worry about it. If it has 4x4, you'll be fine for mild off roading.
   / Ford Excursion - I think I must have one! Comments welcome. #60
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A58017)
2005 INTERNATIONAL...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
