Ford8n Antifreeze
   / Ford8n Antifreeze #101
them caps at TSC ARE Junk and flimsy! anyhow the governor on my 8n is leaking oil should i just replace the seal in it or replace the hole the governor or get a repair kit and do the seal its dripping from the bottom dont no exactly were
pull the gov housing off.. check for warping on a flat surface.. over tightening bolts will warp the housing.
sometiems you can sand them lightly on a table to true them.. then use a new gasket.
if the innards are good.. no need to repalce.
ps.. remember where the botls came out of and make sur ethey find them same holes.. don't be putting longer bolts in them holes needin shorter bolts.. or you'll be back here asking how to repalce a fiber cam gear.. :)
   / Ford8n Antifreeze
i also notice that is losing hardly any oil from this area wondering if i even need to replace it its staid near the same oil level for 2 months
   / Ford8n Antifreeze #103
if a single drip, or simple 'wet spot'.. i'd hardly worry.. if 'drips' and or stream.. fix.
IMHO.. it's probably the former...
   / Ford8n Antifreeze
what i was thinkin
2004 International 7500 T/A Roll-Off Truck (A50323)
2004 International...
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A50323)
2019 International...
A1 Terminator 3pt Blower w/ 60 Gal Tank (A50120)
A1 Terminator 3pt...
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
