Ford8n Antifreeze
   / Ford8n Antifreeze #81
i know, i was just messing with you. I have had it to, said yes but not had the dbl post or maybe i have?
   / Ford8n Antifreeze #82
I agree with soundguy pull the radiator and have it fixed. Easy enough repair to just let it go.If its leaking its comtaminating the ground and not to mention if a animal finds the drips.Only takes a teaspoon to kill a large dog
   / Ford8n Antifreeze #83
plus a leak stop fix can fail when you need it the most. no need to dump a 1500$ engine on a 75$ rad fix...
   / Ford8n Antifreeze
their is no leak its just leakin from the overflow
   / Ford8n Antifreeze
but in my case Sc i get antifreeze that comes out of the overflow and it has bubbles in the radiator is that bad? what do i need to do do i need to start it up and let it run alot longer to see if the bubbles go away?
   / Ford8n Antifreeze #87
if you are getting continous bubbles in a radiator.. you have a compression gas leak. could be a head gasket.. could be a cracked head.. etc.
if the engine has been apart.. after warming, retorque head. if still got bubbles.. time for a looksee.
   / Ford8n Antifreeze
my oil is clean my radiator is clean no white smoke
   / Ford8n Antifreeze #89
but when cold do you have bubbles in radiator? that is a sign of compression leak. Pull plugs see if one is cleaner than the other if so that could be the leaky cyl, its being steam cleaned.
   / Ford8n Antifreeze #90
yep.. might not be going into the oil ( water ).. and it might not be sucking water into a combust chamber.. might just be intruding into cooling sys.
remember rad pressure is 4 psi.. combustion cyl pressure is 90 psi spec min...
2016 Kubota SVL75-2 (A50120)
2016 Kubota...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Ford Tractor (A50120)
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
Ford F800 (A50121)
Ford F800 (A50121)
