Ford8n Antifreeze
   / Ford8n Antifreeze
so i should just replace the water pump and all is good
   / Ford8n Antifreeze #92
boy.. hard to follow this thread as we are talking about a case sc in a 8n thread.. :)
   / Ford8n Antifreeze #93
What?? are you the guy with the blown head or what? Im with sound guy this post is all over the board now. I guess your the OP as you have 8n listed in the side?
But NO replacing a water pump will not fix bubbles in the Rad. Now if this is not what your asking forgive me, but this seems to be turning into a post on just about anything tractor related?
Edit: your the same guy i see! So my answer stands about the waterpump. The water pump is unrelated to a blown head.
There should not be BUBBLES of air (combusion gasses) inside your radiator, its a sealed system. Yes you can have turbulance and small air bubbles if you have a low radiator and for somereason sucked air into the water pump but you probably wont notice them unless your draining and refilling your Rad. The bubbles are from a blown head gasket and when the piston compresses it forces gasses around the bad gasket into the cooling jackets and out into the radiator where they bubble up.
   / Ford8n Antifreeze #94
the confusion is that he apparently has a case sc or similar with a water pump shaft seal going out.. leaking water and sucking air into the rad and he has merged the topics... :(
   / Ford8n Antifreeze #95
I was thinking that since he mentioned a water pump that there was a possibility of sucking air and causing bubbles that way. But i did miss where he said he had a leaking shaft on the water pump, which is why i said what i did.
Yea this is getting confusing. Best if we are to keep talking about this to start a new thread.
   / Ford8n Antifreeze #96
yup! i agree. hard to tell what's bouncing back and forth after a day has past .. etc..
   / Ford8n Antifreeze
i am in need of a new radiator cap for my 50 ford 8n the one i have now does not have a spring in it like the new one do and it only has one hole in it is it ok to use the new radiator cap with 2 holes and spring?
   / Ford8n Antifreeze #98
a 4psi cap is what you need. tractor supply carries one. any one that firts and is 4 psi is fine.
   / Ford8n Antifreeze
them caps at TSC ARE Junk and flimsy! anyhow the governor on my 8n is leaking oil should i just replace the seal in it or replace the hole the governor or get a repair kit and do the seal its dripping from the bottom dont no exactly were
   / Ford8n Antifreeze #100
WOW, i thought my spelling was bad as well as puntuation!!!
Just pointing it out as folks point out mine!!
"hole" instead of whole
"no" instead of Know
This just makes comprehension a bit difficult as you read is all, with the incorrect words.
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
377694 (A51572)
377694 (A51572)
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
