Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones
While I ponder how to get my stuck taper pin out... Someone school me on the "Start of Delivery" method for timing a diesel.
Thanks,
Randy
Attached is the Yanmar service manual.
Timing is covered in here.
L-A-Manual-Complete.pdf
I can’t post it for some reason.
I’ll work on getting it on line.
90cummins
   / Forum for air cooled diesel engines and clones #455
Thanks 90Cummins.. I actually have a hard copy of that manual. I usually use it just for looking up part numbers and exploded views. It never dawned on me there would be a section on "Timing"
Happy to help!!
90cummins over & out👍
   / Forum for air cooled diesel engines and clones #457
help to all .1st post and it will be a bit long,but I need some schooling and am so happy I found this site ,read all 46 pages and have learned a bunch but now have a few questions .but I will back up from the start ,get yourself a coffee . Canadian welder / fitter that retired at 53 and drove a 31 ft motorhome pulling a 30 ft enclosed trailer to Panama lived in mh for 3 yrs while I built and in that time I bought a Firman 200 amp DC welder /generator from a box stop .had about 200/300 hours when the gen end died ,pulled the gen off and kept the diesel . which now kind of brings us up to date 13 years later .have a 40 ft seacan as a little shop completely equipped welder wise plus a 9x20 benchtop lathe ,benchtop mill and a small drill press . always into motorcycles and antiques up home and got this idea I want to build as close to real as I can a 1908 Sears motor buggy ( think doctors buggy ) with a motor under the seat .it came with a 10 hp 2 cyl opposed , that where mine will not be model correct ,yes I want to put the diesel in it if I can ,if not the gen out of the motorhome that is sitting still in my yard has a 2 cyl oppoed gas motor ..back to the diesel I did oil changes in the hours that I used it and read the very good manual that came with it but until I started reading this blog somehow I missed the screen oil filter ,( slam palm into forehead ) after reading about others finding metal in the filter I went to the shop and pulled the motor out of storage and rolled it on its side like someone mentioned and found where the filter is ,thinking the worse I pulled it and found nothing in the filter when I washed it over a paper towel .nada nothing ,put a paper towel on finger and wiped inside were filter fits ,had to go out into the sun to get it to shine on the 4 super super small flecks on that towel . drained oil and found nothing . sometimes the Lord takes care of idiots and fools and I was taken care of I think . now the questions ,being a genset it had that one leaver throttle to hold it at 3600 rpm .good for that job but not mine ,can they be run at slow speeds? .I need it to act like a car gas pedal does .I have not started it yet as the starter was weak when I was using it so pulled it off and took it to a friend that rebuilds such things .any and all adviseis welcome now that you have a idea on what I want to do with it .the only name sort of that I can find on mine says CE in a couple of spots and it was a 2006 model so maybe they were a good builder .thanks and sorry this is so long and glad to be here .doug
Well it looks like you have a good engine there.
A clean filter screen = a happy engine.
Yes it can be operated at slower speeds or variable speeds like an auto.
I’m running my L100 at 2700 rpm which turns a 28v 450 amp NIEHOFF military alternator.
I run at at 2700 to improve fuel efficiency while also meeting my minimum amperage requirement.
.90cummins
   / Forum for air cooled diesel engines and clones #459
I知 running my L100 at 2700 rpm which turns a 28v 450 amp NIEHOFF military alternator.
.90cummins
Thank you for the fast reply 90 ..i know you started this thread and was hoping you would reply as you know everything to know about these motors i think .just glad i can slow it down .the speed was controled by a leaver on the tiller and topped out about 25 mph . Everything should be able to get here except the leaf springs and 4 buggy wheels and the big sprockets on the rear wheels as itis chain drive .do you think there will be any back pressure prolbems if i pull the muffler off and put a pipe and muffler under the car
   / Forum for air cooled diesel engines and clones #460
I joined to comment here & follow this thread.
I've been working on the L-Series Yanmar engines for a year or so now refurbishing US Military surplus equipment that has them. Learned a lot & collected a lot of manuals with documentation on them.
I made a bunch of videos with "how too's" on these engines that I'm sure will apply to the "Chanmar" clones as I call them.
Am I able to share YouTube videos on the forum as a new member?
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2017 Ford F-150 Pickup Truck 4x4 (A56858)
2017 Ford F-150...
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
