Found an old Modern boxblade
   / Found an old Modern boxblade #11
Thanks for the link, I do plan on getting some rippers. I estimate the weight around 1100 -1200lbs. Good thing about the box blades, they are basically the same used as they are new, can't really were them out, I'm happy about the find.
May not be able to wear them out but you can dang sure bend the heck out of them. Ask me how I know. :mad:
   / Found an old Modern boxblade #12
Streamin, the next time I'm out at my property, I'll take some pics and measurements of my scarifiers and the V-clips that hold them in place. I'll post them on here so you can at least determine whether it matches yours so you can include or eliminate the Gannon/Woods scarifiers and clips as a potential source for yours.
   / Found an old Modern boxblade #13
Looks very similar to my gill sr20, with the hinged scarifiers and rear blade. As MTV ranch said, mine are the notched scarifiers with a rod running perpendicular to the points. It locks in behind the scarifiers and is held in place with hitch pins. I have also sheared a couple of shanks at the notches.
That would be great, I am only familiar with the one kind and not sure if those are the ones, thanks. BTW, they want about $450 to do the powder coating, will be waiting on that for now.
   / Found an old Modern boxblade #15
I'd just paint it to match your tractor.
Sent from my GT-P3113 using TractorByNet
   / Found an old Modern boxblade #16
Here's a pic showing the scarifier clips on my Gannon, if it helps.
If you want to paint the BB, Sherwin Williams Sher-Kem (with the hardener) is tough stuff and looks good too. They can tint it pretty much any color you want. Both my trailer and Gannon were sprayed with it using a cheap HF gravity feed gun.
   / Found an old Modern boxblade #17
I agree TSC don't last but these hold up great!
   / Found an old Modern boxblade #18
If I paint any of my implements, I think I'll just paint them black. That way, I won't have to worry about it if I trade tractors.
Yes that helps, I think that is what I need however less common for aftermarket, thanks for taking that pic.
That is a great idea, it is a bit ironic that I paint vehicles all day for customers at my body shop but I am too lazy to do it on my own stuff, as the saying holds true... It is more the sandblasting that I don't care to do so the powder coating includes that but looks like I will be taking a day on the weekend to do it myself.
   / Found an old Modern boxblade #20
Sandblasting? Are you going to use it, or is this a piece of Modern art?... :laughing:
3/8in. AR500 Gong Target (A46502)
3/8in. AR500 Gong...
3060 (A49339)
3060 (A49339)
60in. Work Bench (A46502)
60in. Work Bench...
2007 Mack MR688S Sermac 5RZ53 53 Meter Concrete Pump Truck (A45336)
2007 Mack MR688S...
2007 GMC Sierra 1500 Ext. Cab Pickup Truck (A46684)
2007 GMC Sierra...
(10) 10ft. Coral Panels (A49339)
(10) 10ft. Coral...
