Front end goes out again!!!
   / Front end goes out again!!! #141
it IS an MF problem if they make an update to the front end, the OP has posted enough info to prove this is an originally a BAD DESIGN.. searching on Google for exact results in this case requires exact, and varying, search terms, which can vary greatly depending on the poster!..
Ah, i stand corrected. So the issue has been corrected then?
   / Front end goes out again!!! #142
You say "if they make an update". But have they made an update to the front end? Isn't the 1526 and the 1531 the same front axle? And the 1526 is the same as always and still a current product.
So did MF create an update for the front axle? I don't find any instance of it. . . . . Do you?
   / Front end goes out again!!! #143
I actually got this thread confused with another one, that had the front wheel/hub falling off, because the manufacturer used 3 small bolts to hold it on, and they made the update to use 1 large bolt instead, sorry for the confusion, this is a long thread, and it took me a while to read enough of it to realize the mistake.. this thread. https://www.tractorbynet.com/forums/mahindra-owning-operating/399212-left-front-wheel-fell-out.html
John Deere RSX860i (A56469)
John Deere RSX860i...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
Transport Frame Mini Skid Steer Attachment (A55851)
Transport Frame...
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
gravely riding mower (A55758)
gravely riding...
