Tires Front Wheel Frozen on Ford 1310 (4WD)
   / Front Wheel Frozen on Ford 1310 (4WD) #1
kc5sii
Oklahoma
Ford 1310, '72 Cub 1410, Swisher 66" ZTR -w- 60" Trail Mower.
My RF wheel would not turn after a recent cold weather episode. The Temp had been very cold. (about -5F) I put a forced air heater on it a few minutes and rocked the machine back and forth. It finally broke free without any bad sounds.
Nothing seemed to be dragging or clanging after it broke free. Any idea what could have caused that?
Dave
   / Front Wheel Frozen on Ford 1310 (4WD) #2
I'd think only water turning to ice.
   / Front Wheel Frozen on Ford 1310 (4WD) #3
Drain it and refill when warm, its possible you could break the case.
Regular 90Wt Gear oil?
   / Front Wheel Frozen on Ford 1310 (4WD) #5
No, Ford-134A or equivalent is recommended. Quite thiner than 90 weight.
JC,
Thanks, Any idea what that is?
   / Front Wheel Frozen on Ford 1310 (4WD) #7
What is "what"?:confused:
Ford 134 A is the hyd fluid recommended FWA reduction gear and the rest of hydraulic system if that was your question.
JC,
Thanks,
I have an I&T manual but it doesn't talk about lubricants. I guess I need to find something that conforms to the 134A spec. I assume youæ±*e saying that's the same stuff I'd use in the rear hydraulic transmission case too.
BTW, I can't tell from the I&T drawing. Does each front wheel have a separate reservoir, or does the whole front transaxle fill and empty as one reservoir?
Dave
JC,
   / Front Wheel Frozen on Ford 1310 (4WD) #9
Thanks,
....BTW, I can't tell from the I&T drawing. Does each front wheel have a separate reservoir, or does the whole front transaxle fill and empty as one reservoir?
Dave
Dave
Should be able to tell that from looking at the axle housing. Also should be able to determine how to check the oil level, either by a dipstick or a side plug.
   / Front Wheel Frozen on Ford 1310 (4WD) #10
Dave,
I just changed the front axle fluid on my 1320, so I'll assume your tractor is the same. Jack up the front end of the tractor, block it, and take off both front wheels. There should be a drain plug at the bottom of each differential housing plus one more in the center. It is on the left side. Drink a pot of coffee while it slowly drains. You may want to rock the axle back and forth to get it to drain completely. Stick the plugs back in.
There are three filler holes. One at the top of each differential housing out by the wheels and one in the center, which contains the dipstick. Fill the outer ones first until the fluid is level with the top of the hole and put the plugs back in place. Next, start filling the center one. Rock the axle back and forth to distibute the fluid. The New Holland mechanic told me to check the level WITHOUT screwing the dipstick back in. Make sure the axle is level when checking it.
To answer your other question, I believe the axle is filled as one unit, but having the seperate filler holes helps ensure the differentials on the axle gets the proper amount of oil. Hope this helps.
   / Front Wheel Frozen on Ford 1310 (4WD) #11
Thanks,
I have an I&T manual but it doesn't talk about lubricants. I guess I need to find something that conforms to the 134A spec. I assume you羆*e saying that's the same stuff I'd use in the rear hydraulic transmission case too.
Dave
Ditto on "CPB Engineer" and what he said. I don't have a FWA assist to give you first hand knowledge. But it is very clear from diagrams on NH website and IT that there is a drain on bottom of the reduction gear case on each side. and there is a fill point on either side of axle pivot point. Two drain holes and two fill holes. The hyd oil in the diffy and front axle is the same type but front does not have a reservoir as the rest. You might look at the PDF I attached below.
JC,
  • 1310 front axle.pdf
   / Front Wheel Frozen on Ford 1310 (4WD) #12
Except for engine oil and air breather the 134C (C is newer spec) oil is the recommended oil. Alot of UTF oil claims to meet Ford 134C and should be OK if it states the claim on the container.
So, once I find something that conforms to the Ford 133 A (or C) spec that's what I use in both the front transaxle and the rear differential / gearbox / hydraulic reservoir. Right?
So, other than motor oil and copious amounts of grease on all my zerk fittings, those are pretty much the only lubricants I will have to worry about for normal maintenance? I'm not trying to pin you down, just getting things straight for future reference.
   / Front Wheel Frozen on Ford 1310 (4WD) #14
I went and found my owners manual for the 1700 (slightly older & bigger but similar). It does not show the m2c134d (full spec name). 80W gear oil with anti-foam below 86F and 90w or 140W above 86F. The I&T manual does show the final gear reduction cases at each wheel separate from the main drive axle.
.23 quarts in the gear reduction cases and 2.5 quart for the main axle.
Sorry about the wrong oil in the front!!
   / Front Wheel Frozen on Ford 1310 (4WD) #15
Ditto on what Mostl Gas said.Sorry for incorrect info. The summary sheet was not as clear. Pleas look at the pdf below.
JC,
  • front axle lub.pdf
I'm not sure I follow. Gear oil in the front axle. Then M2C-134D in the transmission/hydraulic (rear)
   / Front Wheel Frozen on Ford 1310 (4WD) #17
The rear axle, hydraulics and transmission are one sump and you use the M2C-134A or newer.
A number of UTF fluids say they meet the C revision which is newer than the A rev that is referenced in my owner's manual.
I drained all three reservoirs this weekend. The Right side dumped about 1/2 cup oil with about 1 cup of water. I 'm not sure that's the right proportion. :D But, it certainly explains the freezing.
What concerns me was there were only about two table spoons of oil in the differential. It didn't really look like there were any leaks. I know the tractor was overloaded at some point and broke the frame. I wonder if the fluid was drained then never replaced. I refilled all of the reservoirs and haven稚 see a drop of oil a few a hours after refilling... err I mean filling them.
I can see that there was seepage around the vertical pivot point on the RF wheel. I've ordered a seal Kit for that.
Has anyone replaced one of those seals? I have an I&T manual but some practical advice would go a long way. I assume once I see what all comes in the kit, l'll have a better idea how best to get into it.
Dave
Got her done. Piece of cake. I ended up replacing the bearing just below the seal. It took some major hits. the other bearigns seemed to be okay so I didnt invite more trouble.
Thanks for the help.
   / Front Wheel Frozen on Ford 1310 (4WD) #20
Glad to hear you are back in business.
What does it mean "It took some major hits" ??
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
2021 CATERPILLAR 306 CR EXCAVATOR (A60429)
2021 CATERPILLAR...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
UNUSED 1RGC40 HIGH END MINI GOLF CART (A60432)
UNUSED 1RGC40 HIGH...
