Fuel filler cap came off
   / Fuel filler cap came off #1
confederatemule
On my Mahindra 5145 the fuel filler cap came off without being unscrewed. The part that the cap screws into came off with the cap, bringing the filter with it. The tank neck has threads in it but the part that goes there is smaller than the neck.
Has anyone had this happen to them? If so, how did you fix the problem?
I am gonna try to send pictures from my phone. I do internet from a desk top computer.
Thanks for any help.
Mule
I hope these Pictures help explain it.
   / Fuel filler cap came off #3
Looks like they simply put the wrong filter holder in the tank neck , too small and appears threads don’t match. Looks like you need to find the correct one and thread in. Mahindra dealer nearby?
I have contacted the nearest dealer and he had no answers. My next call will be to the dealer 60 miles away.
Well, the second closest dealer has never heard of such a thing. The tank comes as one complete unit, assembled at the factory.
   / Fuel filler cap came off #6
It looks like that was built so the screen can be easily removed for cleaning. It's a simple physics problem in that it took less effort to unscrew the whole assembly than just the filler cap. I'd put some thread locker on the screen threads and clean and lightly grease the filler cap threads so it comes off easier. Obviously use fingernail polish or non-permanent thread lock so it can be taken apart at a later time without damage.
That is how it looks to me.
I am going to try to explain how the filler neck is set up on my 5145. The dealer, where I bought it in March of 2022, says they are all just like mine and they have never tried to repair one, they replace the tank.
The black plastic filler cap screws into and out of the metal filler neck. The tabs on the metal filler neck are, in fact, there to keep the metal filler neck from turning when the cap is screwed on or off. The filter screen fits into the metal filler neck. It appears that the metal filler neck will "screw" into the tank neck, but that is NOT how it works. The outside diameter of the metal filler neck is smaller than the inside diameter of the filler neck opening in the tank. The top flange, where the 4 tabs are, is shaped to "sit" on top of the rim of the tank neck opening. From the factory the metal filler neck is glued in place with the 4 tabs in corresponding slots provided for them in the outer part of the tank filler neck rim.
NOT QUALITY ENGINEERING!
From appearances the tank was designed to have a metal filler neck screwed into it and then the tabs on the metal filler neck pressed into the slots around the outside of the tank filler neck to keep it from screwing out when the plastic filler cap is removed. But mine is not put together this way.
2018 Ford Fusion Hybird (A55758)
2018 Ford Fusion...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
New/Unused Root Rake for CFG Mini Excavator (A54865)
New/Unused Root...
5 - JACK STANDS (A55745)
5 - JACK STANDS...
Pair of New 700/40-225 Alliance Tires with Rims (A55302)
Pair of New...
New/Unused Quick Attach Auger with Three Bits (A54865)
New/Unused Quick...
