mllud
- Joined
- Oct 4, 2019
- Messages
- 318
- Location
- Missourian
- Tractor
- Massey Ferguson / New Holland 3010/ Ford 3550 Backhoe
Pumpman or anyone else that knows.
Do these fitting on a pop tester fit a cav injector pump. High pressure pipes 'A' and 'B' type with m.m. size nuts (12 X 1.5) and (14 X 1.5) for connections.
It also says. For nozzle size R, S and T
Here is the pop tester I'm looking at. Diesel Injector Nozzle Tester Pop Pressure Tester Dual Scale 6-8 PSI BAR | eBay
I did adjust the injectors using the injector pump and cranking the engine to set the injector nozzle pressure. I kept adjusting the spray to the smallest atomized pattern I could get on all three injectors. Since this adjustment is at cranking speed I added a quarter turn extra to the spring to slow pop off at a higher rpm. This is not by any book but the tractor ran. It was flooded and took a minute to clear up. Its still smoking a little but it smoked some before. I needed to get it started to leak check all my new power steering lines and new fuel lines. I had to tighten up one power steering fitting and a couple fuel leaks. I'm about to scrap the old dual filters and buy a new set. I need to leak check before putting the dash back on and blocking access to the plumbing.
I will order the pop off tester to reset the injectors to spec. I just need to know it has the right fittings to hook it up. All t could find on the fittings is that its Bhp or bp- something. I lost that link. I know its a British fitting.
The pop tester is just like the one [radios] gave me a link to.
Thank's to everyone for your help
