Fuel Pump Frustration
   / Fuel Pump Frustration #21
Fuel pump replacement should be easy. Look for a reciprocating pump rated for low pressure - such as a marine pump for a carb Mercruiser. For my truck with a 7.3 IDI I installed a Walbro FRB pump. This is a very high quality marine grade, but the IDI world uses many lower cost pumps - such as for reefer units; google "Facet fuel pumps". Lots of options and relatively cheap.
Btw, if you are foaming then you are drawing in air somewhere. Check between the pump intake and the tank, something else is wrong.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
Toro Mower (A50324)
Toro Mower (A50324)
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
CROSSTECH 4200X 57" HYD BRUSH CUTTER (A51406)
CROSSTECH 4200X...
