Gas Can Advice Needed
   / Gas Can Advice Needed #1
Shaman
ok, this is my pickle.
I always bought 2 handle gas cans. They were vented and worked really well.
Due to moving several times, I got down to a 1G, 2.5G and a 5G.
Went to store the other day to get 2 more 5G and all they had were CARB cans.
I bought two and they are TERRIBLE.
Now, I can not find the same cans I have vented and with two handles.
I tried looking online and the closest I could find was the Blitz self-venting non-CARB. Does the self venting can run as smoothly as the vented version. I can find a B&S 5G vented can, but I can only find 'front side view' pictures and can not see if it is double handled (top and back). Looking for Plastic Low End. I don't need high end Jerry Can style or the Fuel Caddy style. Does the Blitz self venting can run as smoothly as the vented version.
Anyone have recommendation for a NON-CARB cans, two handle, and smooth flowing?
   / Gas Can Advice Needed #2
For those of us in less regulated states, "CARB" means "California Air Resources Board". According to the web site No-Spill CARB Gasoline cans "CARB compliant fuel cans & nozzles are required for retail sale in California, Connecticut, D.C., Delaware, Maine, Maryland, New Hampshire, New Jersey, New York, Pennsylvania, Texas and some counties in Virginia."
I bought several Blitz 5 gallon two-handle self-venting cans/jugs at Walmart last year and I love them. They pour pretty fast, but not quite as fast as vented, and they do keep pouring and you don't have to mess with the vent cap getting lost after the little cheapo plastic strap breaks. Unfortunately, I think Walmart is carrying some other brand now. And I guess those who live in one of the states listed above, you won't find them anywhere locally.
   / Gas Can Advice Needed #3
Thanks for the "Heads Up" on CARB cans... I need a couple of new cans and live in a restricted state, but will be traveling to Ohio this weekend. I'll get what I need there. I had no idea that PA joined the People's Democratic Republik of California. :D
   / Gas Can Advice Needed #4
Just picked up a 6-gal Blitz with self-venting nozzle at Sam's Club. Like Ted said, not as fast as the old style cans, but much better than that CARB crap.
   / Gas Can Advice Needed #5
You should see what happens when the old style gas cans show up at auctions in my neck of the woods. It's common to find 8 people bidding against eachother for a gas can. :)
   / Gas Can Advice Needed #6
I have four 5-gallon (2 diesel, 2 gas) and one 1-gallon (2-stroke gas/oil mix) Blitz self venting gas cans, and I like them for the following reasons:
1. The spout seals tightly to the can unlike the old flexible plastic spout that leaked fuel everywhere.
2. The spout is rigid, which means one less thing to fight with when hucking a 5-gallon can of fuel into the tractor's tank. The old flexible plastic spouts would never hold their position.
3. No vent caps to lose when the plastic strap breaks.
The three old style flexible plastic spout cans I had still worked; but they pissed me off, so I put them by the side of the road (empty of course) and let passersby who wanted them take them.
   / Gas Can Advice Needed #7
Interesting...I live in Texas and have not seen the CARB cans at any of the local stores. My local Wally World does have the Blitz self venting plastic cans that work and are worlds better than what they previously built with those leaking flex tubes, I also threw them away after getting the self venting cans.
I don't have to use a funnel for filling my tractor...just put it in the hole and lay it on the hood and walk away if I want...self fueling:)
Found some.
Looks like old Blitz I have.
6G can
   / Gas Can Advice Needed #9
Speaking of gas cans. Someone told me that if you leave fuel in those red plastic cans that that the red dye will leak into the fuel. I tried to find the answer to this but have not seen it anywhere. Is this true or false.
Also, if you put a fuel preservative (extender) into gasoline, how long can it sit and still be good and usable?
   / Gas Can Advice Needed #10
Don't know if they're still available as I haven't seen any for a while, but Rubbermaid used to make cans in 1 1/4, 2 1/2, & 5 gal.,. These were tapered out at the bottom so that they wouldn't turn over. If you turned one over in a vehicle, you would have more serious things to worry about than the gas can! I don't like the looks of any of the cans I see for sale now! :mad:
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
KOMATSU D65EX-18 CRAWLER DOZER (A60429)
KOMATSU D65EX-18...
Farmall H (A59814)
Farmall H (A59814)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2000 FORD F550 SUPER DUTY SERVICE TRUCK (A60430)
2000 FORD F550...
