Gas from dirt?
   / Gas from dirt? #21
There are plenty of fuel sources , even low polluting types but the oil and coal companies have a vested interest in stopping them ever seeing the light of day (by any means) .
Everyone tells us that it is impossible to power engines from water , NASA is ecstatic they have found frozen water beneath the surface of the Moon . They proudly tell us they can refuel rockets with that water to go further into space . Who's lying ?
Transportation of fuel and size of equipment needed to move it make it expensive in space. Local fuel that only takes 1/6th the energy to move cuts costs. Solar panels work better in space too.
   / Gas from dirt? #22
For every discovery in a lab that makes it to the real world millions are proven to work but will never actually be useful and die a quiet death. It's not a matter of can it be done but can it be done and not break the bank. Ethanol is a prime example. For it to be a fuel to replace gas it would require too much prime farm land. Fuel cells are another example. The energy needed to get the Hydrogen is just too much to make it a viable source. So both will be ideas that will help us cut down the use of gas but never replacing it.
Of course we shouldn't stop looking, even if it's a solution that just cuts a few percentage points off of what we use now. Someday they may even lay the foundation to a solution.
   / Gas from dirt? #23
Well, sometimes, government programs and university research produce interesting things...the internet, for example, is based on technology developed by DARPA (Defense Advanced Research Agency).
Now, let's everybody vote on a scale from 1 to 10 as to where the internet fits into negatively or positively impacting your life.
Me, it's about a 9 on positive impact.
But, it surely is more fun to make nonspecific blanket statements about the ineptitude or mendacity of others.
   / Gas from dirt? #27
I dont know: the link works for me, here I will try to post the whole article
From a startup snagging headlines to DIYers posting plans, water-powered cars have been all over the Web recently--not to mention stuffing my email inbox.
Yes, you can run your car on water. All it takes is to build a "water-burning hybrid" is the installation of a simple, often home-made electrolysis cell under the hood of your vehicle. The key is to take electricity from the car's electrical system to electrolyze water into a gaseous mixture of hydrogen and oxygen, often referred to as Brown's Gas or HHO or oxyhydrogen. Typically, the mixture is in a ratio of 2:1 hydrogen atoms to oxygen atoms. This is then immediately piped into the intake manifold to replace some of the expensive gasoline you've been paying through the nose for these last couple of months. These simple "kits" will increase your fuel economy and decrease your bills and dependence on foreign petroleum by anywhere from 15 to 300 percent.
There's even a Japanese company, Genepax, showing off a prototype that runs on nothing but water. On June 13 Reuters published a report on the prototype, complete with a now much-blogged-about video even showing an innocuous gray box in the Genepax vehicle'strunk supplying all the power to drive the car. All you have to do is add an occasional bottle of Evian (or tea, or whatever aqueous fluid is handy), then drive all over without ever needing gasoline.
So what do I think about all of this? Why haven't I tested and written about this stuff? It's certain to Change the World As We Know It ... right?
Rubbish.
The only real definitive claim Genepax makes on its Web site is that its process is going to save the world from global warming. (A request for comment was not returned at press time.) Their Water Energy System (WES) appears to be nothing more than a fuel cell converting the hydrogen and oxygen back into electricity, which is used to run to a motor that drives the wheels. Fuel cell technology is well-understood and pretty efficient at changing hydrogen and oxygen into electricity and water, which is where we came in, right? Except the hydrogen came from water in the first place--something doesn't add up here.
Here's the deal, people: There ain't no such thing as a free lunch.
There is energy in water. Chemically, it's locked up in the atomic bonds between the hydrogen and oxygen atoms. When the hydrogen and oxygen combine, whether it's in a fuel cell, internal combustion engine running on hydrogen, or a jury-rigged pickup truck with an electrolysis cell in the bed, there's energy left over in the form of heat or electrons. That's converted to mechanical energy by the pistons and crankshaft or electrical motors to move the vehicle.
Problem: It takes exactly the same amount of energy to pry those hydrogen and oxygen atoms apart inside the electrolysis cell as you get back when they recombine inside the fuel cell. The laws of thermodynamics haven't changed, in spite of any hype you read on some blog or news aggregator. Subtract the losses to heat in the engine and alternator and electrolysis cell, and you're losing energy, not gaining it--period.
But enough about Genepax, which is sort of tangential to my main thesis here, and on to a more common topic in my mail que: HHO as a means of extending the fuel economy of conventional IC engines.
HHO enthusiasts--from hypermilers to Average Joes desperate to save at the pump--suggest that hydrogen changes the way gasoline burns in the combustion chamber, making it burn more efficiently or faster. Okay, there have been a couple of engineering papers that suggest a trace of hydrogen can change the combustion characteristics of ultra-lean-burning stratified-charge engines. Properly managed H2 enrichment seems to increase the burn rate of the hydrocarbons in the cylinder, extracting more energy. However, these studies only suggest increases in fuel economy by a few percentage points and don't apply unless the engine is running far too lean for decent emissions. That's a long way from the outrageous claims of as much as 300-percent improvements in economy that I see on the Internet and in my mailbox.
There's no reason to believe that even more modest increases claimed by some of the ads could be achieved by a conventional, computer-controlled automobile engine running under closed-loop driving--that is, the computer's ability to sample the oxygen output of the engine's exhaust in real time and slew the fuel/air ratio for big mpg and small emissions. The combustion chamber events are far different in the type of ultra-lean-burn engines where hydrogen enrichment has been seen to help. Ultra-lean means there's a lot of extra oxygen around for the hydrogen to have something to react with--far more than the very modest amount we're sucking in from the typical homebrew hydrogen generator made from a Mason jar. And remember, these studies deal with hydrogen enrichment under closely-controlled lab conditions, not spraying an uncontrolled amount of hydrogen-oxygen mixture into your air cleaner.
I'm building a water-electrolyzer car--right now. The electrolysis cell assembly is on my workbench and ready to install, so stay tuned for the test results soon. If it works, then you can believe the hype.
   / Gas from dirt? #30
And you would be waaaaay smarter than the Japanese and everyone else that has done it .:rolleyes:
   / Gas from dirt? #31
Yes, I am pretty smart for a hillbilly, I paid attention in school, and I dont fall for scams very easy. I have been scammed a few times, but not too often:laughing:
Here is your "japanese that did it" info:
Genepax Water Energy System
In June 2008, Japanese company Genepax unveiled a car which it claims runs on only water and air,[23] and many news outlets dubbed the vehicle a "water-fuel car".[24] The company says it "cannot [reveal] the core part of this invention, yet,[25] but it has disclosed that the system uses an onboard energy generator (a "membrane electrode assembly") to extract the hydrogen using a "mechanism which is similar to the method in which hydrogen is produced by a reaction of metal hydride and water".[26] The hydrogen is then used to generate energy to run the car. This has led to speculation that the metal hydride is consumed in the process and is the ultimate source of the car's energy, making the car a hydride-fuelled "hydrogen on demand" vehicle, rather than water-fuelled as claimed.[27][28][29] On the company's website the energy source is explained only with the words "Chemical reaction"[30]. The science and technology magazine Popular Mechanics has described Genepax's claims as "Rubbish."[31]
Genepax's web site has been offline since February 2009.
James K0UA
   / Gas from dirt? #32
You know, why am I wasting my time trying to educate you believers in perpetual motion? and water cars, and evil oil companies, and all of that. You know if you want to believe in all these wonderful energy sources, are just around the corner, or are supressed by oil companies, or government. Then please do so! If it makes you feel good, what harm is there in that. If you want to put your money where your mouth is, please do. Invest away, I shall warn no more..
K0UA ...out...
   / Gas from dirt?
If the bonds were too easy to break the earth could go up in a ball of fire.:(
   / Gas from dirt? #34
I guess I should have read a couple of Blogs like old mate above did so I could form a better opinion .
And now that he has emphasised it so strongly and assured me he is correct I no longer believe in that Devil work . :laughing::laughing::laughing:
   / Gas from dirt? #35
   / Gas from dirt? #36
James K0UA
Good to see some science being applied to the secret process hype. If it was as straightforward as is portrayed in the hype they could be virtually instant trillionares just by selling the energy they could produce from their faucet. Their water bills could get a little high tho.:D
larry
   / Gas from dirt? #38
   / Gas from dirt? #40
If the car worked as they said, why would they need to add water? Burning hydrogen creates water so just put it back in the tank. Could it be that their secret cell actually supplies something that fuels it also? And that contaminates the water so it can't go back into the tank? And is it hazardous to humans? What is the replacement cost for the secret box when it dies? A solar panel can get you free hydrogen but how are you going to store it? The hydrogen has to be under pressure to be stored and that takes energy. To create the first hydrogen for the car would require energy input to start it off with. Just like you can create fresh water from sea water, it takes energy to split the hydrogen from the water in the first place. And energy produced to drive the vehicle is consumed energy so you have to keep adding it somewhere.
2023 CATERPILLAR 972 WHEEL LOADER (A60429)
2023 CATERPILLAR...
CAT 930M (A58214)
CAT 930M (A58214)
skeleton / rock bucket (A56857)
skeleton / rock...
2348 (A60432)
2348 (A60432)
2014 Kia Sedona Van (A59231)
2014 Kia Sedona...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
