GC 2300 mf 2350 loader parts
   / GC 2300 mf 2350 loader parts #11
Wow... mine broke yesterday, too! Called the dealer, they had one of each of the two types in stock: one that has the same threads on both ends, the other that has a smaller thread on the valve end (which is right where it breaks off, of course!).
At any rate, I too welded the snapped-off end back on, but when I went to find a die to re-capture the two rows of threads I slobbered up, I find it's a "SPECIAL" size.....
Mine's the two-thread type. I didn't think they were metric, however- the knob end is 3/8 x 16 pitch, the valve end is 5/16 x 20 pitch. Seems like they're maybe Whitworth? Man, I haven't had to deal with Whitworth since I built a Jag 3.5-liter XK engine back in 1967!!
I was quoted $35 for the lever, BTW.
   / GC 2300 mf 2350 loader parts #13
Yep, they're metric! Like an idiot, I didn't check my metric taps & dies to check for that before....:confused2:
My weld held OK to finish clean-up yesterday, but broke right off as soon as I tried to hit "float" today.:mad:
I found a suitable metric bolt, cut the head off it, then cut about 1/2" off the shaft and re-welded the thread section of the bolt onto the shaft --with gusto, this time (and clean steel)-- and it has held, so far.
Discovered the threads on the valve end of the shaft are 8mm x 1.25. All this in the middle of the forecasted 2-3" of snow... that turned into 10" and is still coming down!:eek: Of course, I had to hurry because wife and I needed to get out to go to a family Christmas/New Year's thing... oh well, never a dull moment! Just got back-- some real greasy roads out there.
Take care if you're driving in this area tonight! WBB
My orginal dealer quit selling MF 3 years ago ...... so I called the nearest dealer 45 miles away. They located one at the warehouse and will send it to my house. I took the broken handle - had a good friend weld a bolt end (8 x 1.25 mm) - then welded a sleeve over the splice. Temp fix until new part comes.
   / GC 2300 mf 2350 loader parts #16
Took a drive to the dealer today and picked up a spare shaft. The part # listed above, 71516035, is what I got (the one with the smaller thread on the valve end), but I did see the other one- same thread on both ends. Must be the "new, improved" version; looks much less likely to snap off. Interestingly, that one had a sticker on it indicating it was made in Sweden.
So now I have a spare, but my second weld --using a cut off 8mm x 1.25 bolt-- appears to be holding up just fine. And the part was less than quoted- "only" $26.90.:thumbsup: WBB
   / GC 2300 mf 2350 loader parts #17
Masterful engineering, making it thinner, right were all the stress is. Who could see that as a potential problem? :confused2:
When mine breaks, I'll repair it, or make a new one.
   / GC 2300 mf 2350 loader parts #18
My joystick broke also. Already fixed it once a couple years ago. Guess I will order a new one from Jacks.
Got my new 'stick' - price was $27.00 from my closest dealer (50 miles) they drop shipped it to my home from the warehouse. ($20.00) - should of ordered thru Jacks.
   / GC 2300 mf 2350 loader parts #20
Code:
Jack's didn't have any - back ordered. I ordered one yesterday from Waterman Farm Machinery Massey Ferguson
HOMEMADE HEAVY DUTY FIRE PIT RING, BLACK (A57192)
HOMEMADE HEAVY...
10 Bale Hay Graplle (A56469)
10 Bale Hay...
UNUSED FUTURE BS43 43" HYD BOX BROOM SWEEPER (A57193)
UNUSED FUTURE BS43...
2021 MDB TF150R 84" HYD MULCHING HEAD (A52707)
2021 MDB TF150R...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
