OP
        Massey2019
Think I have figured out what the issue is.
First, the manual is wrong. The description (image) of the fuses do not match the wiring diagram. Go figure.
So, there is a feed (green wire) off the fuse that keeps blowing. The right side running and turn signal rear work fine. When I disconnect the connection that feeds the left running and turn, fuse is fine. As soon as I hook it up and turn on the ignition, fuse blows.
Isloated that set of wired and ran a continuity check on it. Appears it is damaged but is inside of flex plastic wrap, so will have to take things apart and replace it.
Ordered wire and will replace this week. I think this should fix the issue.
Once again, appreciate the help on this issue!
