GC1705 Fuel & Temp Gage Issue
   / GC1705 Fuel & Temp Gage Issue
Think I have figured out what the issue is.
First, the manual is wrong. The description (image) of the fuses do not match the wiring diagram. Go figure.
So, there is a feed (green wire) off the fuse that keeps blowing. The right side running and turn signal rear work fine. When I disconnect the connection that feeds the left running and turn, fuse is fine. As soon as I hook it up and turn on the ignition, fuse blows.
Isloated that set of wired and ran a continuity check on it. Appears it is damaged but is inside of flex plastic wrap, so will have to take things apart and replace it.
Ordered wire and will replace this week. I think this should fix the issue.
Once again, appreciate the help on this issue!
Yeh, so not being an electrical person really made this a fun experience! Picking up some wiring and will be replacing the damaged connections in the next couple of days.
Love when the documentation is wrong.
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A55745)
2013 3400QB...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2021 CASE IH Steiger 540 AFS Connect QuadTrac (A53485)
2021 CASE IH...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
