GC2410 Hood
   / GC2410 Hood #21
I had thought about making a single large cover but never got around to it. Mine didn't even come with a temp gauge; I had to add one (center). Here's what my instrument panel looks like - gauges are really tiny!
   / GC2410 Hood
As we get older those gauges get even smaller :( You would never know the one you added didn't belong there great job!
   / GC2410 Hood #23
bet you don't get the tachometer shrieking in single digit temps though.
had to pull my underhood "grill" shape thick cardboard to lay flat inside it to prevent the fan from pulling so much cold air over cable end.so far so good.
   / GC2410 Hood #24
Could we please have a more thorough explanation of this please. I've been disconnecting mine when this happens.
   / GC2410 Hood #25
No, you're right, I never have had that problem -- but I know many others have had on the newer GCs....
   / GC2410 Hood #26
I'll grab a pic of the area later today. not sure if 26 series hood same as 24 series though
   / GC2410 Hood #27
you can see part of cardboard laying in there due to label. only blocked the flat area did not want to block all air.
   / GC2410 Hood
Hi all!
I pulled the hood off and I had a friend that does welding and he welled the snot out of it and as expected the paint in those areas needed to be repaired so I started out only doing that but then I had other areas that had scratches and places where the paint was worn down so one thing led to another and I ended up painting the whole hood, I have never done any type of auto body but over all it came out pretty decent, I was short on time and dealing with a wrist pain so working on it was a tad difficult. I figure as long as it is painted it is protected and if I have to ever redo the hood for whatever reason I have a better idea on what needs to be done having this been my maiden voyage into the Auto body waters.
Thanks everyone for your input and pictures and of course the advice and all. Pics show the Primer stage then inside the hood where the plate is re-welded and painted and the other 2 pics show the finished product :)
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
UNUSED JCT HYD TRENCHER (A57193)
UNUSED JCT HYD...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
UNUSED JCT HYD VIBRATORY PLATE COMPACTOR (A57193)
UNUSED JCT HYD...
2005 Ford F-150 Crew Cab Pickup Truck (A55852)
2005 Ford F-150...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
