GC2600 tachometer/squealing noise
   / GC2600 tachometer/squealing noise #1
piercedtiger
Newark Valley, NY
2011 Massey Ferguson GC2600 DL100
Today I had been using my GC2600 for probably at least 20 minutes after letting it warm up around 10 minutes. After using the loader to make several passes on my yard to move snow into a pile for the kids I heard a squealing noise, and the tach shot up over red line. The engine RPMs did not change, and I could throttle up/down without issue. I shut the engine down, did a quick visual inspection, and couldn't see anything wrong so I started back up. Engine sounded normal, however the tach needle is still pegged all the way to the right, past red line, hitting the bottom of the cluster. I used the tractor for another 15-20 minutes when the squealing came back, fluctuated in tone a bit, then faded away.
I can live without an RPM readout, but the noise concerns me. Any thoughts? :confused: I'd been having trouble with the throttle cable freezing up until I sprayed Lock-Ease on both ends and worked the throttle for several minutes last weekend. Could the cable for that have started to freeze up too? I noticed it was about 20F when I went inside after putting the tractor away, and I know my knees and hands were starting to freeze!
   / GC2600 tachometer/squealing noise #2
Search this forum for threads involving the dreaded "squealing tach" on 2600 series tractors-- there are a number of folks who have had this problem. Seems like it doesn't do any harm, other than the noise and maybe hour reading being off. IIRC, most fixed the problem by cleaning/drying the cable, applying lube, then sealing the ends (and maybe re-routing it) so moisture can't get into the cable. ijk
   / GC2600 tachometer/squealing noise #3
Mine does it when is cold, I disconnected last winter, hooked back up once it warmed up, just wire tied it up so it wouldn't slap around
Sent from my iPad using TractorByNet
Great. Thanks guys! I feel better knowing it's a common issue now. I wasn't even sure what the heck to search for! I figured I'd look into how to get the cable off once it warms back up a bit. Down to 14 now, but it's only Friday so I still have a couple days for it to warm up and play with it.
I know this is probably a dumb question, but why do all the cables on these things wrap around the engine at least once? Throttle, tach, etc. *sigh*
   / GC2600 tachometer/squealing noise #5
Not just in GC 2600. My GC2400 is doing the same thing.
Yeah, I see it's a very common issue now. Guess I'll be pulling the cable tomorrow, and maybe the tach for the **** of it and take them in the house to thaw and see if there's anything I can clean. My impact wrench stopped working this summer, and when I opened it up the air tool oil looked like vaseline. Once I cleaned that out and re-oiled it worked again. Kinda hoping this will be something similar.
Well, I pulled the gauge cluster out today. When I took the tach drive piece off the needle snapped back to 0. I cleaned out the old grease, put in some new, put it back together, and it works again. Will keep an eye on it, but it's fixed for now!
   / GC2600 tachometer/squealing noise #8
Great! :cool2:
Just in time for the NEXT round of "wintery mix"? I'll be glad when it gets cold enough --and STAYS cold enough-- to just deal with snow!
   / GC2600 tachometer/squealing noise #9
Squealing speedometer cables were very common in the past. Regular lube or a silicon one worked well.
Great! :cool2:
Yup! We're supposed to get another 6" or so by Tuesday I think. I'll get to see if loading the rear tires makes a difference too since I did that on Saturday. Need to get some more washer fluid to do the fronts next, and I think that will have a bigger impact on steering. That was definitely questionable last time it snowed.
Well now that I know how to get it off without taking the whole gauge cluster out I'll be able to keep it lubed. Also, I think the gears jammed or something because the needle was stuck beyond red line until I took the gear drive off the back, and then it snapped back to zero. Surprisingly nothing looked damaged so I just put it all back together again. :confused3: Although thinking about it now, I should wrap some electrical tape or a zip tie around the cable so the nut doesn't slide all the way down under the battery again. I'm getting tired of fishing for that thing!
1452 (A57192)
1452 (A57192)
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
