generator brands/types
   / generator brands/types
Changed out 2 incandescent for LED in a 1950's indoor entry light fixture and first night noticed the LED now have a faint glow when off... so some power is being consumed... how much don't yet know.
is in on an eye ? you may need to replace the eye. they will glow for a few seconds when you turn the power off, but it should be be on at all when the switch is off. some of the eyes leak enough that they could power an LED and not and incandescent, but it was probably leaking the same amount of power with the incandescent installed.
   / generator brands/types #42
no, its on a timer. Since its in unconditioned space, im limited in the type of timer i can use. I tried a battery backed led digital timer, but batteries failed during winter. So im stuck with an electronic timer.
   / generator brands/types #43
I doubt that any of the popular standbys have an insulated enclosure due to the auto-start features. With an insulated enclosure, it would be fairly simple to keep things fairly warm but it would get expensive a .28 per KWH and you would have to be there to open her up for cooling.
My Generac 16kw has minimal insulation but has a battery and oil filter warmer.
   / generator brands/types #44
While I do have a Generac 16kw which I love so far, it replaced a Briggs and Stratton Storm Response 5500 watt and 8750 surge watts portable. Was\is Junk! It leaks oil between the generator and engine block, had it fixed once under warranty and its leaking again with only 10 hours....
I noticed at Sears the new ones on display were also leaking in the exact same spot.
Cant run two 1\2 HP pumps at the same time with it...8750 surge watts my ars!
   / generator brands/types #45
i have a briggs 6500 portable thats 3 years old. use it alot when working on property and when i was working away on jobs where we had to shut off power. flawless machine. 2 pulls at most to start. noisy, to say the least, but always starts and runs. no oil leaks, actually body of generator is spotless. did not get auto start cause i dont need it for emergencies and did not want to have to plug it in to trickle charge
   / generator brands/types #46
If you switch LEDs with an SCR (Dimmers and Many Timers) you are mostly going to get that faint glow. The only way to switch them completely off is with a simple switch or a relay. But a relay uses power too.
I tried finding a video I saw that explains it, and immediately found ones with misinformation.
Ah, here it is. Big Clive always knows of what he speaks!
Electronically controlled LED lamps glowing when off. - YouTube
   / generator brands/types #47
the more power you generate, the more money it will cost you. The other important consideration is when you buy a low end unit, it will be harder to start the longer you own it. I would avoid Harbor Freight. It might work fine the first couple of times you use it, but it won't work next year.
I'm in Texas and when I lose power, it's in the winter because of ice. Usually it builds up on tree branches and they take out the power lines when they break off. Power can be out for an hour, all day, or even a week.
First thing that I did was get a wood stove. I can keep the house warm all winter from firewood. I can heat water for cooking or bathing on the stove if I have to. I can also grill outside in winter on my gas grill if the power is off.
What I really need electricity for is lights, TV, the Computer, and charging our phones. This is the bare minimum for me and my wife. I do not need to keep the refrigerators or freezer going in winter. They will last a full week with the outside temperatures in the 20's to 40's.
After years of struggling with small engines on lawn mowers and other things, I finally decided that I will only buy Honda. It's more money upfront, but the quality and reliability more them makes it worth the added cost. I spent almost a grand for my little Honda generator that can handle 13 amps and run all day on a tank of gas. It starts every time and it's quiet enough that most people don't even know its running when it's on a 100 foot extension cord for our parties down at the pond. When we lose power, I put it on the porch, fire it up and run an extension cord into the living room. That's where we are during the evenings, and it just takes a minute to plug everything in.
I thought about propane because it's so stable and clean burning. I also thought about diesel, but it's a lot more money. I drain my Honda generator when I'm done with it, or run it until its dry. I never store it with gas in the tank. I usually have a 5 gallon gas can for my lawn mower, or Mule or log splitter, so it's not a big deal to make sure it's full when we know a storm is coming. Worse case is that I have to drive to the gas station to get it filled.
Wow Eddie... I had to look twice to see if I wrote this. Am about the same word for word.
Except
I run pure gas ONLY in all gas engines here except for the car.
I also have a Honda EU1000I for simple things lights tv etc.
Dont drain them unless they sit over a year. Installed a Hutch Mountain fuel shut off in them
   / generator brands/types #48
I have the original tank of gas in my Honda 2000i, going on about 10 years now. I use sta-bil and there has been no noticeable degradation of the gas. Garage temperatures run between 45-70 degrees. Never above 70.
   / generator brands/types #49
Just a single fixture controlled by two 1950 wall switches original to the home... No dimmers, controllers or remotes... Also no ground wire on metal "J" boxes.
   / generator brands/types #50
I believe, I have seen the capacitance from the Parallel romex run to the switch cause a sensitive LED to glow when off as well.
My step Dad was a licensed electrician working in a hot mill. He was German and always bieched about how this whole NA ground system was stupid and redundant.
3650 (A47477)
3650 (A47477)
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
FENCE PANELS (A58214)
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
