GFI ?????????
/ GFI ????????? #21
So a better or different brand of GFI is something to try. You can't really tell anything about the devices RFI (Radio Frequency Interference) immunity, so it's a hit and miss. At least the cost is less than what it cost to play with hydraulics.
As far as corrective actions go, one thing I did not see in the post is whether or not anything was plugged into the GFI. This might be a clue because there are three ways the RFI can get into the device:
1) RF hits wires on device plugged into the RFI
2) RF hits wires in the house connected to the RFI
3) RF is directly getting into the device's circuits
For all three possibilities, a new device (different brand probably) is the easiest thing to try.
So whether or not something is plugged in affects (1). Solution is to put ferrite beads on the cord of what is plugged into the outlet close to the outlet.
If the "way in" is (2), then put ferrite beads on the AC wires where they come into the device.
If the "way in" for the RFI is (3), you could try changing out the plastic box the GFI outlet is in for a metal one and try a metal plate on it. A metal plate outlet cover might also be a quick and cheap thing to try.
Radio Shack (Americas Technology Store, which explains a lot about the state of the country but that's a different topic) may still sell clip on ferrite beads. If not, I can post other sources. This is a somewhat intensive medium expensive trial and error process with no guarantee of success. You'll need to clamp the bead or barrel around all three wires, might need more than one due to inside diameter of the bead issues.
This assumes you have to use the radio close to the outlet, and have to have a GFI outlet.
VHF portable radios (up to about 150 MHz) can be set to output up to 7 watts out. 800 MHz portable radios are usually set to less than 1.5 watts out. For mobiles, VHF runs 25 to 100W, and 800 MHz run 5 to 8 watts. As frequency get higher, the human body shows more heating effect. There is still much debate about how much effect RF non ionizing radiation has on humans. I believe cell phones max out in the .3 to .6 watt range, not as sure on that one. At higher frequencies, it takes shorter length pieces of wire to pick up the signal. So electronic circuits that were unaffected by 150 MHz radios get interference they never saw before from 800 MHz radios. Since the wavelength of 800 MHz signals is much smaller than 150 MHz, the signal can also "sneak in" to devices through smaller holes. If you've noticed that AM radio in a truck fades when you drive under a bridge but FM doesn't it's because of the wavelength. AM radio (at 1 MHz or so) has a very long wavelength and the "hole" that is under the bridge is too small to have the signal pass through. FM radio at about 100 MHz passes through no problem. A hole in a device that is around 1.5 inches is enough to let the 800 MHz signal get in. For 150 MHz, that hole has to be about 8 inches. Think of these sizes as they relate to outlet and wiring boxes and you can see that the introduction of 800 MHz radios starts to expose many devices to RFI that they have never seen before.
Hope this background makes sense. I also hope the geeks in the crowd will cut me some slack here, I've made a lot of assumptions and generalizations in order to present a first order view of the situation.
Pete
/ GFI ????????? #22
yep.. good ole' isotropic propogation.
any chance to use a handheld extension mic on that radio and leave it clipped to somewhere 'ahem'.. safer..
soundguy
/ GFI ????????? #23
soundguy
That's all I see now, prob for convenience but guess it's safer to.
Though not sure what damage it might do down around the mid section :eek:
/ GFI ????????? #24
you already got kids.. right? :)
soundguy
/ GFI ?????????
You guys are great. I am saving all these posts for my son to read. We don't have grandkids, so I am having him read ALL the posts.
/ GFI ????????? #26
It would seem from a layman's standpoint, that any transmission, or leakage through out the circuit greater than 5 mA between the neutral and hot will cause the GFI to trip. This is the UL standard. This could be from a real problem or an induced problem as in radio transmission.
Ground Fault Interrupter
Talking about RF transmission, while in the Navy many years ago, a friend of mine said, see that guy carrying a box of florescent lights, he said watch this, and he triggered off the radar on the P2V, and caused the florescent bulbs to light. He said RF energy. We also had a guy claiming the radar made him sterile. He was serious, but could never prove it. Another situation, just about out of 10 times a P3V passes over my house, the wireless doorbell rings. Every time I hear the doorbell, I listen for the P3V and I can recognize the sound of the engines. Apparently there is some transmission from the P3 that is on the same frequency or is a side band of the transmission. So if I hear the doorbell and the P3, I don't bother going to the door. I have heard this thousands of times before, because I have lived here for about 35 years, and I flew in the P3's for about 15 years.
Bet that took a while to figure out when it first started.
/ GFI ????????? #27
If you refer to the schematic of a typical GFI, you will notice that a torrid coil exists, where a voltage is induced when the current through the neutral when the voltage drop is not the same with respect to ground.
This is accomplished by passing the neutral (and hot side of the line) through the torrid, while the ground bypasses it, thus creating a differential.
SO, any RF in the immediate vicinity is induced into the coil wound around the torrid. The voltage induced into the winding of this coil is AC and is used to trigger a shut off when the magnitude exceeds a certain value.
A capacitor external to this circuit would only tend to reduce the induction, not eliminate it. The RF frequency answers to the 'tuned circuit' characteristic of the torrid coil, making it frequency sensitive and often selective.
Since we're dealing with 50-60 Hz, a small value capacitor (0.0001uf at over 600v) would not affect the circuit. However, the best location is across the output of the torrid sensing coil (within the GFI). Some manufacturers do make a GFI with a degree of RF immunity. You won't find them on the shelves at your big box stores, but the engineering department of the larger manufacturers are able to supply some 'factory modified' units that will reduce or eliminate the RF trip problem.
It just takes a couple of phone calls and a little patience. Good luck!!
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
