GFI ?????????
   / GFI ????????? #11
I'm in the entertainment business and this is pretty common. It has to do with the equipment powering the mic.
Audio Noise and AC Systems
This will explain it beter than I ever could, but be assured I had the same problem with a new $3,000 Electrical theatrical distro box five minuted before a show and was beyoun upset.
It's how the amp is throwing the signal back. The GFI are so sensitive that when they pick up the slightest and I do mean slightest anomonly they trip, well, because they are designed to.
   / GFI ?????????
Thanks all, I am still concerned, but will check the grounding. He lives in a trailer, so grounding could be the issue.
Catdriver, my brain is smokin after trying to absorb that article. It does give me a place to start though.
   / GFI ????????? #13
There is nothing wrong with the house wiring. The RFI from the radio is causing transient currents to flow along the wires (and EVERY conductive material in the house), which trips the GFI. If I park the pickup close to the house and transmit on HF (much lower freq than what your son is using) at 100w, I actually trip BREAKERS in the home!
Other than dropping output power or finding a less sensitive area of the trailer, there's not much you can do about it.
Shielding the wires, which wouldn't be feasible in a house, would help.
You could try swapping out the gfi unit, simply because higher quality units may not be as susceptible to rfi, or not as bothered by the frequency being used.
As for the health issue caused by RF, I'd not worry about the max 7 watts that HT could be putting out. It is nothing compared to the rf out there from everything in todays modern aged. Just think what the rf from the 1 million watt broadcast station down the street is doing!
E
   / GFI ????????? #14
It would seem from a layman's standpoint, that any transmission, or leakage through out the circuit greater than 5 mA between the neutral and hot will cause the GFI to trip. This is the UL standard. This could be from a real problem or an induced problem as in radio transmission.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gfi.html
Talking about RF transmission, while in the Navy many years ago, a friend of mine said, see that guy carrying a box of florescent lights, he said watch this, and he triggered off the radar on the P2V, and caused the florescent bulbs to light. He said RF energy. We also had a guy claiming the radar made him sterile. He was serious, but could never prove it. Another situation, just about out of 10 times a P3V passes over my house, the wireless doorbell rings. Every time I hear the doorbell, I listen for the P3V and I can recognize the sound of the engines. Apparently there is some transmission from the P3 that is on the same frequency or is a side band of the transmission. So if I hear the doorbell and the P3, I don't bother going to the door. I have heard this thousands of times before, because I have lived here for about 35 years, and I flew in the P3's for about 15 years.
   / GFI ????????? #16
The difference is that the devices with the label you mention (remotes, tvs, baby monitors, etc) are "secondary users" of the band that they are using and as secondary users, they are not allowed to cause interference to the primary users. Cell phones, radios (Police, Amateur (Ham) or Business), etc are licensed as the primary users of their respective bands and as such are allowed use more power and can cause interference to the secondary users without any legal repercussions.
An example of this is what happens (happened?) to garage door openers when a navy ship comes into port with the radar on, the frequencies conflict and people with RF garage door openers cannot remotely open their doors as the radar is on the same band and is MUCH more powerful, drowning out as it were the signal from the remote to the opener.
Aaron Z
Yup, that's what I was trying to get at, "Priority users have the right of way" if you will.
You don't want a soccer mom with her family radio interfering with a military exercise.
Not sure it relates to the gfi issue but it might.
   / GFI ????????? #17
You might want to tell him to not be using his radio near/in any hospitals as they do shut off machines. Few if any Cops seem to think they can do what they want regardless of others problems. The trailer has the extra metal shielding of the metal exterior & can cause signal degrade and as such the radios will power up into high output which can cause additional power output and trip the sensitive equipment anywhere in the 50 yard radius..
The local cops would key their radios and trip car alarms all around just for fun and to see if anyone was home to shut the car alarms off and if they were away they were citing the people to earn extra income!! I know all about that!!! You have 45 seconds to shut off the alarm here or else find a nice 45 buck for 1st offense ticket on the car. Car alarms have settings as to how long they chirp, the 5 sec chirp and so on on most of them, mine was set for 15 sec. the cop would keep clicking the mic and bang new ticket...
mark
   / GFI ????????? #18
"As for the health issue caused by RF, I'd not worry about the max 7 watts that HT could be putting out. It is nothing compared to the rf out there from everything in todays modern aged. Just think what the rf from the 1 million watt broadcast station down the street is doing!"
The power falls off with the inverse sqaure of the distance. So that 7 watt HT held 6 inches from a person's head is exposing the person to electric fields hundreds of times larger than the 1million watt broadcast station one mile away.
Best pactice for low exposure to RF is when able to to use a whip antenna mounted out side a car and to use the HT only when needed when out side of the car.
   / GFI ????????? #19
Yep.. I think that's exactly the issue.. even with no current flowing.. IE. nothing plugged in.. if the gfci see's an imballance betweent he lines it trips.. and the rf induced flow could be enough.
I bet that xmitter can make a neon or flourescent lamp pulse or glow...
soundguy
Ground Fault Interrupter
   / GFI ????????? #20
Yes, I agree, I was only making a point. There is RF everywhere.
Yep, external ant. is the answer, but that kinda limits the usefulness of a handheld in the first place.
It's just rf. There's nothing wrong with the radio. There's no voodoo, it's merely the side effect of a sloppy engineering job on the part of the gfi manufacturer.
Here's a little on GFI theory.
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
