Give me some ideas on what trailer i need for kubota l3301
   / Give me some ideas on what trailer i need for kubota l3301 #11
One thing I didn't see mentioned is width. My Hudson 12K equiment trailer only has 78" between the fenders. I had to switch the rear wheels around to get my M4700 on. 80" would be a lot nicer. 84" would be ideal for me.
   / Give me some ideas on what trailer i need for kubota l3301 #12
I would go with a 20' 10k car trailer. I definitely would not go any shorter than a 18'. I like car trailers because you can load stuff over the sides unlike a landscape trailer and you can load stuff over the back or let it overhang unlike an equipment trailer.
   / Give me some ideas on what trailer i need for kubota l3301 #13
I don't know the new model enough, but based on my experience in the L series, I would echo 94Bullit. I'm short at 16', but it works in a pinch. And I need the 10k rating with loaded tires, loader, and implements. And you probably will too.
   / Give me some ideas on what trailer i need for kubota l3301 #14
A car/equipment trailer w/ flat sides, stake pockets can easily be transformed into a trailer with sides like a landscape trailer or an enclosed trailer.
Hudson 16'+2' dovetail with M4700
Hudson 16'+2' dovetail with sides for carrying stuff, takes about an hour and seven 2"x6"x16', some 2x4's and about $100 of nuts and bolts.
Hudson 16'+2' dovetail with enclosed 4' high body, takes about 2 more hours and 9 sheets of plywood plus a few bits and pieces.
For it's next iteration I'll probably add a foot or two to the side height.
   / Give me some ideas on what trailer i need for kubota l3301 #15
I used a 16 foot 7 k landscape trailer for years. It was lightweight and pulled very well however. When it comes to Halling tractors I found I was constantly overloading it with weight and length. I recently upgraded to a 20 foot 10 K car hauler with standup ramps. So far I've been happy with it but it is a heavier trailer so you can feel it more when it's empty and being longer it takes a slightly larger turning radius to make a turn. Everyone said to stay away from the standup ramps because they take away from your ability to overhang the back. But I rarely do that so they have worked out very well especially that they are spring loaded and easy to lift.
   / Give me some ideas on what trailer i need for kubota l3301 #16
Here is a pic of the 16' 7 k you can see why I needed a bigger trailer. My tractor is the same size as a kioti ck 27 for a size reference.
   / Give me some ideas on what trailer i need for kubota l3301 #17
Here is the new set up.
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2014 FREIGHTLINER...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2020 Kinze 3505 High Speed 6/11 Planter (A55314)
2020 Kinze 3505...
