Give me some ideas on what trailer i need for kubota l3301
   / Give me some ideas on what trailer i need for kubota l3301 #11
One thing I didn't see mentioned is width. My Hudson 12K equiment trailer only has 78" between the fenders. I had to switch the rear wheels around to get my M4700 on. 80" would be a lot nicer. 84" would be ideal for me.
   / Give me some ideas on what trailer i need for kubota l3301 #12
I would go with a 20' 10k car trailer. I definitely would not go any shorter than a 18'. I like car trailers because you can load stuff over the sides unlike a landscape trailer and you can load stuff over the back or let it overhang unlike an equipment trailer.
   / Give me some ideas on what trailer i need for kubota l3301 #13
I don't know the new model enough, but based on my experience in the L series, I would echo 94Bullit. I'm short at 16', but it works in a pinch. And I need the 10k rating with loaded tires, loader, and implements. And you probably will too.
   / Give me some ideas on what trailer i need for kubota l3301 #14
A car/equipment trailer w/ flat sides, stake pockets can easily be transformed into a trailer with sides like a landscape trailer or an enclosed trailer.
Hudson 16'+2' dovetail with M4700
Hudson 16'+2' dovetail with sides for carrying stuff, takes about an hour and seven 2"x6"x16', some 2x4's and about $100 of nuts and bolts.
Hudson 16'+2' dovetail with enclosed 4' high body, takes about 2 more hours and 9 sheets of plywood plus a few bits and pieces.
For it's next iteration I'll probably add a foot or two to the side height.
   / Give me some ideas on what trailer i need for kubota l3301 #15
I used a 16 foot 7 k landscape trailer for years. It was lightweight and pulled very well however. When it comes to Halling tractors I found I was constantly overloading it with weight and length. I recently upgraded to a 20 foot 10 K car hauler with standup ramps. So far I've been happy with it but it is a heavier trailer so you can feel it more when it's empty and being longer it takes a slightly larger turning radius to make a turn. Everyone said to stay away from the standup ramps because they take away from your ability to overhang the back. But I rarely do that so they have worked out very well especially that they are spring loaded and easy to lift.
   / Give me some ideas on what trailer i need for kubota l3301 #16
Here is a pic of the 16' 7 k you can see why I needed a bigger trailer. My tractor is the same size as a kioti ck 27 for a size reference.
   / Give me some ideas on what trailer i need for kubota l3301 #17
Here is the new set up.
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2860 (A56857)
2860 (A56857)
Chevy 2500HD (A56436)
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
