Good grease gun needed!
   / Good grease gun needed! #1
Sid Post
Platinum Member
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
If you wanted a good grease gun, one that will work with tough zerks that put up a bit of struggle, what would you get? I need one with a fixed neck and a long handle (no pistol grips). I have tried the cheaper options from all the local places, Atwoods, Harbor Freight, WalMart, TSC, etc. I expect to spend ~$60 but, can go a bit higher if there is good reason. On the other hand, if what I want is available cheaper, I'm certainly receptive.
I live in East Texas and grew up in Central Oklahoma so, retail locations along the Interstates are fair game but, I'm expecting to mail order something.
TIA,
Sid
   / Good grease gun needed! #2
I've had good experiences with Lincoln brand grease guns but am now using a Milwaukee M18 with a LockNLube.
   / Good grease gun needed! #3
- To get a good Grease Gun, you WILL need to spend more than $60 !
Depending on the amount of greasing you have to do, I do my own vehicles, included a car, a truck and tractor... and a few smaller things requiring grease.
I purchased a DeWalt Battery Operated Grease Gun; it is powerful, gets grease in where you would think it wouldn't; I added a Lock-n-Lube Grease head to hold to the Fittings, best thing I ever did.
It isn't the lightest gun out there but it is the best one I have ever used, the hose on the gun isn't as long as I would like but it can be replaced as I did the head.
It gets the job done !
Lock-N-Lube sell a foot pumped grease gun... a little too much grease for my needs and a little too expensive; more than the DeWalt !
Good Luck on your search, post up what you find !
   / Good grease gun needed! #4
DeWalt 20V ($124)
I bought a new Lincoln pneumatic, and threw it away.
   / Good grease gun needed! #5
Go with a Alemite if you want a lever gun. One of their guns is a high pressure unit pushing 15,000lbs. I have a old unit that I can switch the linkage from high pressure to high volume.
   / Good grease gun needed! #6
I use Lincoln 1147 manual grease guns (lever with hose). The 1148 is the same gun but with a fixed neck. The Alemite A500 is also well regarded. Both are 10,000psi rated guns and are very affordable in the $30 range. I use the Lincoln and put 20 or so tubes through it a year, durability has not been an issue for me with it. I mostly grease equipment so high volume is not needed, higher pressure would be nice, but it would probably just cause me to squirt more grease all over....
The Alemite 6268-2 is the 15K unit that Ruffdog refers to, its currently $720.50 on Amazon.
The Alemite 1056-SE4 is the dual high pressure / high volume unit and is $112.39 on Amazon.
   / Good grease gun needed! #8
Ryobi has worked great for me so far.
   / Good grease gun needed! #9
All my cordless tools are Dewalt so I bought an 18v grease gun. Makes maintenance intervals a pleasure.
   / Good grease gun needed! #10
I have a Lincoln pneumatic hand held I got of an amazon warehouse damaged box deal for 50-ish bucks. Works great and much needed when owning a backhoe.
Spirit Electric Tri-Scooter (A53316)
Spirit Electric...
2019 Ford Fusion Sedan (A55758)
2019 Ford Fusion...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
Doosan 7' Bucket (A50775)
Doosan 7' Bucket...
