Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Exact same thing that I've heard.. when the situation warrants it.. a double tap to center .. then check.. if the attack is continuing.. then fire more shots.. keep applying this rule till the attack stops.. then call for help. My handgun instructor was a police trainer / nra certified.. sounds like his advice is 'common' to what others have reported in handgun training courses.. etc. IMHO.. it's good advice.
soundguy
soundguy
The use of potentially lethal force is still an issue even in self defense friendly states. If you are in fear of your life (a situation where a prudent individual would reasonably expect to be in danger of bodily harm) then it is prudent to use your weapon to defend yourself.
You DO NOT employ your weapon with the intent to kill the attacker. If you have no other reasonable alternative you use your weapon to stop the attack. All the concealed carry courses of which I am aware teach their students to fire two shots into the "center of mass" and then evaluate if the attack has been stopped or not. If the attacker continues to advance and continues to pose a threat then further shots are reasonable and prudent. The best advice I have been given is that if a double tap to the center of mass doesn't stop the attack then put one between the mustache and the eyebrows.
It is not unreasonable in these times to expect to encounter a person on drugs that although mortally wounded by your double tap may still continue the attack and still pose a lethal threat. The attacker may die (later) from your double tap but could injure or kill you or a family member before ceasing to be a real danger. Hence the need to evaluate the results of the double tap and be ready to follow up with a round between the mustache and eyebrows.
Pat
