Grade of steel used for implements?
   / Grade of steel used for implements? #21
Yes overlapping below; using existing holes is better.
   / Grade of steel used for implements? #22
Yes, I am pretty happy with the robust construction. The limitation is that there are no shear bolts, which may be fine for frequently cultivated soil but a bit of risk for my use. My thinking, and the only option I can spot is to replace these two horizontal bolts with shear bolts.
Thanks, Gus
Shear bolts in those areas may case some frame twisting when one bolt breaks.
I'd suggest a layout where The plow arms are completely on the side with no framework above them.
I'd go with a welded on box tubing extension with fillets in the corners. Also add fillets to the three point arm extensions.
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2003 Big Tex 10PI...
72'' rock / skeleton grapple (A56857)
72'' rock /...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
Hose Reel (A55758)
Hose Reel (A55758)
