Grand L3240
   / Grand L3240
Does anyone have their wife able to run a grand L hydro? Or would a b3000 series be an easier tractor for a 5' -95lb gal. I'm just thinking for snow removal if I'm away at a business meeting...
   / Grand L3240 #22
If she can run B then an L is no problem either:thumbsup:
The L hydros are smoother and stronger than any B I have come across.
   / Grand L3240 #23
I was able to easily teach my 70 year old mother how to operate my Case shuttle shift backhoe. The biggest problem is there are lots of levers that are not found in a car so getting past the intimidation of it is the harder part.
The HST can be started in gear. The lcd panel will tell you when starting if you need to do something like push the clutch in or disengage the PTO. Once they sit in the seat and realize that it's easier than a car to operate and most things are self explained. Take the FEL lever, push it forward it goes down, pull it back it goes up. The 3pt hitch is real simple, higher number the higher it is. The size could be a factor but I believe after a little seat time that quickly goes away and I think being able to easily see all around the tractor is a bigger deal.
   / Grand L3240 #24
My "wife's tractor" is a BX2660, but when needed, she bush hogs with our L5030 HSTC. She is very comfortable in it.
   / Grand L3240 #25
Lots of good advice. As far as size get the biggest tractor that you can afford and have room to maneuver. If you look at tractors side by side there isnt that much difference bwtween the mid size Ls and the large Ls, but you get bigger tires, more ground clearance and more lift capacity front and back.
If you are moving snow have you considered a cab? I went from a small, open station B to the cabbed grand L and would never go back to an open station machine. Just have to be careful in the woods. Other options I have found helpful are the Rimguard loaded rear tires, SSQA, front hydraulics ( I have Kubota's), rear remotes (I have used both sets on mine). The rear remotes can be ordered with a float position which is useful in some application. If you get the cab, rear wipers, rear defogger and work lights have been useful.
The grand Ls are very easy to run. My wife is 5'2" and has no problem running our cabbed machine. She was smiling this summer siting in the cab with the AC and radio on.
   / Grand L3240 #26
One caution about the whole larger is better thing:
If you ever plan to bring it into a garage, don't forget to measure the height of your garage door from the bottom of the door to the garage floor with the door open.
   / Grand L3240 #27
After owning at 3130 and now a 5740 I love the 40 series over the 30 series. I have a 6' bushog and the 31 would turn it, but it would fall on face pretty quick. A small hill would slow it down so much it gets frustrating. The L's are all real close to the same size. I personally would get the 4240. Stronger loader, and it comes in handy, and the 10 extra hp make a huge difference. bushing at 3 mph compared to 5 or 6 without having to keep going into low is priceless. I jumped 25 hp and that thing just doesnt stop.
I didnt think it would make a huge difference, but after having both, its a no brainer for me. It would be like buying a 1 ton truck with either a 200 hp V-6 or a 250 hp V-8. Sure, both will do the job in the same size chassis, just that one will do it much quicker. And if you used your truck to make a living, that extra 50 will make you much happier.
   / Grand L3240 #28
My L3130 HST is easy to operate and my wife and daughters have no problems doing it, but now they understand that the tractor time is my stress relief so they let me do things with the tractor whenever possible.
We bought as much as we could afford, sure would have liked more hp and a cab.. but what we have does a good job. I sure would like some remotes and will probably add some via the aftermarket route someday.
   / Grand L3240 #29
My wife has no problem with our L5740 HTC although she is still getting used to the auto throttle which I always have activated. We used to have a L3710. I had comments from a trucker I had hauling gravel for us. He did this when I was in Europe on business so my wife had to do the leveling. He was surprised how she could have each load spread and leveled and be waiting for him when he got there with the next load. I was looking forward putting the finishing touches on the job when I got home, my way to unwind after a week of meetings and job site visits in a half dozen countries, and she had it all done.
   / Grand L3240 #30
Well after having a L3130 for a few months and then going to a L5740 I can't imagine having anything less. It can do so much more than the 3130 and I don't suffocate in smoke doing it. A real pleasure to operate and no you cannot have too much power.:thumbsup:
KUBOTA U50-4 EXCAVATOR (A51242)
KUBOTA U50-4...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
90018 (A48082)
90018 (A48082)
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
