Grande L30 configuration questions
   / Grande L30 configuration questions #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
It's looking fairly certain that I'll be trading up from my L3010 to either an L4330 or L4630 soon. It'll be a hydrostat, as I live on a very steep hill and like the convenience of the HST. Besides, that's the only tranny my bride will use. But I have some questions
First, I can't live without a backhoe. But the frame on the Woods 7500 reduced my ground clearance so much that I was unable to get the L3010 into some places I needed to dig. On the new tractor I have a choice of the Woods 9000 or the Kubota BH90. Both have a 9 foot reach and similar other specs, so I consider them equal in that regard. But which has the better ground clearance? On my 7500 sometimes the frame scraped, but usually it was the tail end that got hung up as I drove over bumps or stumps. Between the 9000 and the BH90, which offers the driver more maneuverability?
I have aggie tires now and have been fairly happy with them. But there have been times when the ground is wet where I've created trenches in my field (though never got stuck). And other times driving over sapling stumps I've really wished for the extra plies of the R4s. Ditto when picking up large maple logs (12 foot long and up to 18" thick) with the FEL. Realizing that if the new tractor has R4s I'd have to keep the chains on half the year, is the durability worth it?
A plumbing question for the remotes. My L3010 has a separate manifold in the rear that feeds my remotes. One dealer says that's not necessary; he feeds the remotes directly from the FEL manifold and charges $650 less for the installation. Is that kosher? /forums/images/graemlins/confused.gif
TIA, Pete
   / Grande L30 configuration questions #2
Regarding the remotes. You dealer's way works just fine for externally mounted control valves assuming he plumbs it correctly. However you end up with hoses everywhere and a big valve hanging off the fender or ROPS which may be an issue if you are going thru the woods alot (and also with a backhoe). The Kubota remotes will be nicely integrated under the fender (they bolt directly to the case) and hard line plumbed. The hydraulic connections for the backhoe will also be nicely integrated.
In my opinion, for the Grand L's, the factory remotes are the only way to go and well worth the extra money.
   / Grande L30 configuration questions #3
MadReferee:
Their not even "hard line plumbed".
There is a blanking plate on the side of the case that is removed and the first, secdond and third valves are bolted with through capscrews right over the orfices under the blanking plate. The subsequent valves receive oil through the primary valves through passages. That's why Kubota says the valves are "stackable". That's a literal statement. Same thing on my M9 and on our M105 though the valves are mounted "out back" rather than "on the side" of the case.
Either way (105-M9-Grand L) it's a neat, sanitary installation, much better than what Boondox's dealer suggests though his dealer does have a cheaper idea. Extra external plumbing means more hanging things to get caught on objects in your path.
One of the built in costs of the remotes on the Grand L is the install itself. They aren't easy to install (I know, I did mine myself). The tractor must be set on stands, tire removed and you have to be about a gnome to get in there to install the linkage. Once it's in though, it's good forever.
   / Grande L30 configuration questions #4
I guess I didn't make myself very clear on that. By hardlined plumbed I meant from the stackable valve block to the QD couplers is a hard line. In any event, it is a very clean setup.
   / Grande L30 configuration questions #5
Pete,
It's only money. Go ahead and have the Kubota remotes installed. It is a very clean installation. You can always have the dealer install remotes off the loader valve for additional valves up front /forums/images/graemlins/grin.gif
Kevin
Okay, got most of my answers. Definitely aggies, not R4s, as much of my use will be in the woods and near streams: mud.
Definitely going with the Kubota remotes for the clean install.
The only question I still have is which backhoe has the best clearances under and behind the tractor: BH90 or the Woods 9000?
Pete
   / Grande L30 configuration questions #7
Looking at the spec's for the 2 BH's it hard tell which one has more clearance. If I remember when the BH90 came out ground clearance was one of it's strong point. I don't know what it was being compared to. Did you look at the place you bought your tractor from. They have a used BH90 for a good price.
   / Grande L30 configuration questions #8
Pete:
By the way, hows the coffee business?? We sure order it when we can.
I'd take a serious look at a Bradco over the Woods and for sure of the BH90. If I was going to get a hoe for my M9, it would be a Bradco.
One other thing though you are probably aware of it but I'll say it anyway and that is get the round back H.D. bucket, preferrably quick detach. The material bucket is weak in the corners where the scraper edge attaches to the side sheets and it breaks there. That is from my own experience and many weld and grind jobs.
   / Grande L30 configuration questions #9
After checking out the Kubota factory valve location versus where my dealer put the optional dealer installed version, I much pefer the dealer version. The Kubota "neat" way may provide a little more beauty, but what I have offers function over form. Besides, my loader has all of its hoses exposed so the front and the back match /forums/images/graemlins/grin.gif. I use my 1st and 3rd remote extensively and like having them where I have instant access to them.
Daryl -- The coffee business is booming thanks to several new customers including McDonald's in New England! Woohoo!
Neither of my local dealers carry the Bradco hoe, which is a bummer as I'd really wanted to check them out. And I thought about the HD bucket, but after seriously abusing my FEL on Clementine and not doing any damage I figured the std bucket was good enough. Especially with the skidsteer style QR that would let me use pallet forks for some of the heavy work like moving logs.
Pete
2020 Kenworth T880 Tandem Axle Day Cab Road Tractor (A47384)
2020 Kenworth T880...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2015 CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2014 CATERPILLAR 279D SKID STEER (A51242)
2014 CATERPILLAR...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
