Grapple cylinder is too strong
   / Grapple cylinder is too strong #21
Triangle end has giving me no problems
My twisting action was here in the pic.
Now I see, all this time I have been looking at the tips of the teeth/jaws in the first photo that looks like the tip had been broken off. Thanks for showing the damage and straightening me out.
   / Grapple cylinder is too strong #22
IMHO, I would run a separate valve. That way, there are no return lines, nothing hanging out by the cylinder. Adjust your pressure from a $70 log splitter type valve. Probably the most economical way to go too.
   / Grapple cylinder is too strong #23
What valve are you using to operate the grapple? Do you have PB on your FEL valve?
I am using electric over hydraulics for the grapple.
   / Grapple cylinder is too strong #25
Since you have a good valve setup now, I would just add the relief valve and take the relief hose from the relief valve, and feed it into a tee at the tank port of the electric valve, or FEL tank port. You will only need a short hose.
   / Grapple cylinder is too strong #26
I beefed up the grapple attachment point with 1/2" plate and now all is well.
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
1604 (A57192)
1604 (A57192)
Sedan (A59231)
Sedan (A59231)
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59575)
2022 KAUFMAN 2 CAR...
TANK MANIFOLD (A58216)
