Grass and leaf pickup, what do you use, recommend?
   / Grass and leaf pickup, what do you use, recommend? #52
</font><font color="blue" class="small">( Kubotafan,
I purchased the power vac option with my CR several years ago. It has plenty of vacuum power to pick up any and everything that gets close to the nozzle.
ed )</font>
Ed,
How well does it work with pulling Fall leaves from ivy beds etc. ? The leaves really get tangled in the vines. A blower will not loosen them, so I wonder if a vacuum would?
That is my biggest issue that I need help to solve. I wonder if it's a two person job, one with a small rack and the other holds the vacuum hose.
   / Grass and leaf pickup, what do you use, recommend? #53
awlchu,
I use the nozzle to break the leaves from my shrubs and hedges, not sure how the vacuum would perform pulling leaves from an ivy bed without help. I am thinking it probably would be easier with the help of someone pulling the ivy snarls with a rake while vacuuming.
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
BELSHE DT-235 (A55745)
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55302)
UNVERFERTH 330 8...
New/Unused CFG Industrial MX15RX Mini Excavator (A54865)
New/Unused CFG...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
