Grass Pit
/ Grass Pit
4 inch blocks for the dividing walls in the pit. the man in the supply yard kinda overloaded my bro's hilux. when he sees this photo he wont be impressed. there is 96 blocks on the back .its only supposed to carry 750kg max.
/ Grass Pit
this is the second half of the head wall. didnt have enough plywood so had to do it in two sections.
/ Grass Pit
Walls built to divide the pit into two sections. This means that a separate pit can be used each year. this will allow time for the grass and other stuff to rot and turn to compost.would putting worms into it help it to degrade better??
/ Grass Pit
middle wall in the pit
/ Grass Pit #15
Looks good, Ronan. In my part of the world we'd call that a double compost bin instead of a grass pit, but the purpose is the same. Not too many people go to the trouble of building something that nice, but it's certainly a very good idea.
/ Grass Pit #16
Greetings!
Great looking pit you have there.
Now I'm the first to admit I don't know much about composting. I think you have to put a LOT of brown stuff in with the grass clippings to make compost though. And I hope you aren't putting a back wall on the pit. If you did that, then I think you'd have the world's biggest mosquito swamp when it filled up with water! /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif As you probably know, wet grass turns REALLY foul when it gets moldy.
Best wishes,
ron
/ Grass Pit #17
Very nice looking compost pit my friend.
Made a few the easy way for our own use. Since we get a lot of free wood pallets we tie them together using short pieces of romex wire to form an open top box of sorts. Then we fill them with anything that is organic like grass, corn stalks, hay, and waste from meal preparation.
Once the mix has been broken down into compost we pull the wires out holding the pallets together, pull the pallets out and use the FEL to move the mound to wherever it's needed.
The cycle then starts over again to make a fresh pile.
/ Grass Pit #18
I wouln't put worms in it unless you want to cook them. I have had grass piles burn. Or at least smolder really good.
/ Grass Pit
here is a picture of it as can be seen from the garden. one of the objectives was to have no visual effect on the garden
/ Grass Pit
the brother building a small local stone wall to try and finish the job off nicely
Countyline 3pt 5' Box Blade (A60462)
Countyline 3pt 5'...
2015 LAND ROVER RANGE ROVER EVOQUE (A60736)
2015 LAND ROVER...
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
