Grease cylinder rods for storage?
   / Grease cylinder rods for storage? #1
DSM
PA
Kubota BX22
I have the loader and backhoe removed from my BX22 until after the fall leaf deluge. I have the MMM and a Trac Vac mounted. The manuals recommend applying grease to the cylinder piston rods for storage. They will be sitting, indoors, for about 2 months. Is this really necessary? My Dad has had a Case 646 with loader and backhoe for 25 years and we never did this, and never had any rusting. Also, I presume I should clean the grease off before using the attachments?
   / Grease cylinder rods for storage? #2
The piston rods of the cylinders are chromed for wear and rust resistance.
I have put a light film of grease on the rods if the loader was not to be used for a month or so. Of course, turned out, the loader was used more then I expected.
Never wiped the grease off though...first time you cycle the hydraulics, the wipers will take care of that.
Good chrome plating will keep rust at bay. Greasing the rods is a bit of an insurance policy. It's sort of like putting a film of gun oil down the barrel of a rifle.
   / Grease cylinder rods for storage? #3
welcome to the forum! /forums/images/graemlins/smile.gif don't beleive it tis necessary to grease the shafts. if u think u will not be using them for a long time it might make u feel better to give them a light coating of oil. can't hurt.
   / Grease cylinder rods for storage? #4
I usually just spray mine with WD 40 to keep the moisture off when the humidity is high and it is cold..... Iron has a habit of drawing moisture to it under certain conditions.... Some people refer to it as "sweating"....
   / Grease cylinder rods for storage? #5
My dealer recommended greasing the shafts, but only if the loader would be setting for a long period (several months), outside in the weather. Just a light coat of ordinary axle grease.
Steve
   / Grease cylinder rods for storage? #6
I usually don't put anything on the cylinders on my FEL but my backhoe sits for longer. I think grease is the best solution, but I've also used WD40, figuring it is better than nothing. I don't think WD40 will damage the seals - that would be the only concern.
I've also left them sitting for a month or so with no use, no treatment (thought I'd be getting to that job sooner, ya know /forums/images/graemlins/crazy.gif) and have not had any corrosion or sticking. /forums/images/graemlins/laugh.gif
   / Grease cylinder rods for storage? #7
Bringing this post back from the dead...but I am wondering with the new invention (?) of fluid film. Would this be a good option for the cylinder rods?
   / Grease cylinder rods for storage? #8
If I cannot retract all rods, I spray them with Fluid Film if stored outside. That is what I do with my snow blade. Philip.
   / Grease cylinder rods for storage? #9
I use Fluid Film as well. My AG dealer buys in bulk and sprays all their stuff on the lot.
   / Grease cylinder rods for storage? #10
We always applied grease to exposed cylinders of AF equipment going into deep storage AND covered them with paper to keep the dirt out.
Chrome + grease + paper = triple protection
Considering the cost of a new cylinder, a little time and effort is a good investment.
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2018 Deere 323E (A53317)
2018 Deere 323E...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
20704 (A55853)
20704 (A55853)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
