Grease for hitch balls
   / Grease for hitch balls #61
I'm the odd guy out, I use Fluid Film on the ball as well as inside of the hitch. Works perfectly.
Have you tried woolwax? FAQ
PB makes a couple of stickier products in spray cans. One is a chain and cable lube, the other is a garage door track lube. I spritz the inside of the coupler assembly on the trailer with whichever of those I have handy at the moment to keep it free, but nothing on the hitch ball.
I haul a 12k equipment trailer and a 10K enclosed trailer. I spray with Fluid Film or PB garage door track lube, because the cans are handy. I spray a LOT of things with FF but several years ago PB had a special on a "two-fer", a spray can of PB and a can of the garage door lube, so there is plenty "around".
   / Grease for hitch balls #62
I've read about Woolwax here and on the Cummins forum, I'd give it a go when (and if) they get the product into an aerosol spray.
   / Grease for hitch balls #63
Woolwax IS... in an aerosol spray!
   / Grease for hitch balls #64
Dont use crisco, it's shortning.
   / Grease for hitch balls #65
I have never greased a ball, and see no reason to, although something with antiseptic properties might be handy for when I forget the hitch is on the truck and bark my shin on it. A good reason for NOT greasing (besides the obvious ones) is with friction you will establish a ground faster, and keep it established, good insurance against a common trailer wiring failure.
   / Grease for hitch balls #66
Oh no....some people still depend on their trailer electrics grounding through the ball? :eek:
   / Grease for hitch balls #68
Ya, they contribute to the great wrecked trailers photos when they get hit due to no lights or hit something due to bo brakes.
   / Grease for hitch balls #69
I'll take the extra ground, you guys keep greasing yer balls :).
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
2011 Chevrolet Cruze Sedan (A56859)
2011 Chevrolet...
1988 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
1988 FONTAINE...
