As a follow-up...I received the splitter this Friday. It came unassembled, which is actually a good thing since I had to load it into the back of my Tahoe to bring it to where the wood was anyway /forums/images/graemlins/smile.gif. If it was assembled I wouldnt have been able to fit it in. Anyway, it took about an hour to assemble and fill. Took 7 gallons of fluid, which actually took a good while to do. The directions are a bit non-descript, but looking forward in the assembly process helped resolve any issues. The system required you to bleed it before use, which was very simple since it was self bleeding. Simply lowering as raising the ram a dozen times did the trick. After topping her up with more fluid, I towed her over to my pile of logs. The first one I split was easily over two feet. She moaned for a second or two, but the log gave in and split very nicely. After that it was cake....
I am very pleased so far, though I only split for about an hour. I have much more time next week to put her through the paces. Sure beats a sledgehammer and a wedge!!
