Grounding Rod For Portable Generators Necessary?
   / Grounding Rod For Portable Generators Necessary? #21
For computers, TVs, and the delicate stuff its better to buy an inverter generator. When our power goes out the generator powers the two fridges, freezer, well pump, pellet stove, electric skillets, and some lights. No TVs, computers or delicate stuff. Ours isn't an inverter generator.
   / Grounding Rod For Portable Generators Necessary? #22
I've had enough shocks in my life to be tired of them now, so I pound some scrap copper pipe into the soil to use as a ground rod with my little lug-around generator...
   / Grounding Rod For Portable Generators Necessary? #23
My guess is it happened because the generator did not supply clean enough power.
You should use a computer back up power supply, (UPS), between the generator, and electronic appliances until you know your generator set up is safe for your equipment. The UPS is designed to filter the power, and make it safe.
Generally inexpensive generators are not good for supplying clean power.
The ground rods are to protect the user, in the even to a short in the generator. If it functions as it should, you won't need it. If the generator ever fails, and shorts out, it could be very dangerous. Without a good ground, you could become the ground, and that's not going to be good.
While a UPS type power supply will do the job, a standalone power line conditioner/filter is a bit more portable for using with portable generators. I have a couple of these that I use for all of my computing or tv watching while on generator power.
Amazon.com: Apc Av C Type 2 Outlet Wall Mount Power Filter, 120V: Electronics
   / Grounding Rod For Portable Generators Necessary? #24
The APC ups units are exactly what I was refering to, for clean power. It is type I have except it is a 750. Thanks for the reference page.If it is not real critical load,I will use the protector strip, but they come in all types. Mostly by cost as to the protection provided.Jy.
   / Grounding Rod For Portable Generators Necessary? #26
Whenever I use a generator I never used a ground rod for it. Never really seen a need too.
Most times I use it it's sitting on the back of my dads tow truck and I'd always hate to have to use the generator for about an hour or less then go out and re pull the ground rod.
Then other times it's used momentarily when the power goes out.
And I definitely ain't gonna call a licensed electrician to put in a ground rod every time.
It's not rocket science. Get out a hammer and hammer that rod in the ground. lol
Chad
   / Grounding Rod For Portable Generators Necessary? #27
per NEC (Nat Electric Codes) codes, only a permanently installed generator needs a grounding rod installed. Not necessary for portable generator.....ie PORTABLE. Don't need to sweat it. Also as a side note, it can take weeks to months for some ground rods to even function properly. I read a study that showed that in some dry soil conditions, it can take up to 6 months for the ground rods to function properly...something to do with the outside coating on some zinc covered rods to decay enuf for proper grounding.
   / Grounding Rod For Portable Generators Necessary? #28
Maybe you ought to read some more of the code book.What year are you reading??? We don't use Zinc coated,but copperclad, some over 8 ft long...and yeap you can put it down with some water for a better readings if you have ground meter, we do..If you wanted real technical IE Portable is under other regulations around here...Just a little more info, but then we are all semi-anonymous folks here, to use someone else's line?
   / Grounding Rod For Portable Generators Necessary? #29
Okay, now I need to say, NO matter trying to help someone understand on here. There is always going to be someone deny what you said...It is not nice to kick people. Electrical work is like motor oil as opinions and runs in all directions.Regulations are there to protect the consumer and the innocent kid who walks up and is electrocuted on the spot. And yes, I have carried an ungrounded gen-set around in the back of a truck or front-end loader. I always make sure I have new 3 prong cordset to plug into==OR the fault breaker won't do its job if the tool fails.Carelessness is just as bad as ignorance, except you might have know better. ENUF said ,I will get off the box.
   / Grounding Rod For Portable Generators Necessary? #30
A note to those who power their houses with a portable when the power goes out: to protect the guys and gals who come out in that storm to get your power back on for you, you must break all three legs between the house and the transformer. If you think that just flipping the main breaker protects the outgoing lines, you are wrong. You can give shocks out there in the world by current feeding into the neutral lead.
The way I dealt with it is, I power only two light and outlet circuits when the power is down for extended periods. I don't run my shop, heat, or refrigerate with the portable. I do run all my lights and electronics (don't want to miss the big game).
What I did was connect the two circuits' romex to a split duplex outlet next to my breaker box. I put three pronged plugs on each of the romexes going on to those two circuits. They are plugged into that duplex under normal circumstances. When I'm on the generator, I pull the two light/outlet circuit plugs from the temporarily dead house power duplex, and plug them into a ganged duplex on the cable coming in from the generator. Under these conditions, I'm relying on the genset's own breakers.
Our PUD line folks are great heroes of mine. They get out there in all conditions and at all hours. I don't want them to get any shocks from me. They have told me they appreciate this.
BOMAG MPH100R SOIL STABILIZER/RECYCLER (A60429)
BOMAG MPH100R SOIL...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
Takeuchi TB016 (A53317)
Takeuchi TB016...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
