Gt2000 transmission problem
/ Gt2000 transmission problem #1
joeyt70
Gt2000
The bushings on each end of the drive shaft was shot so I replaced them also and charged fluid in transmission and filter then I let it set for a year or longer before I started it up transmission took off like it's suppose to but after a few minutes it slows down pulling
/ Gt2000 transmission problem #2
Use something w 50 oil? Try running the purge procedure. Should be easy to find, but basically get the drive off the ground and start operation in bypass mode for about 10 cycles. Then the same out of the bypass mode.
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A67148)
2015 ALTEC AT200...
2017 Ford F-250 Pickup Truck (A64556)
2017 Ford F-250...
(INOP) 36 BLADE DISC HARROW (A64278)
(INOP) 36 BLADE...
