Muleskinner
It will be Kubota's first real construction tractor I believe. It's a stout package if the specs prove out.
TroyR57 said:Info from Back of Brochure.
Gross Power 59 HP
Max PTO Power 46 HP
Pump Capacity 26.7 gal/min
Loader Lift Capacity to Max height at bucket bottom mid point 2976 lbs
Breakout force at pivot pin 5961.3 lbs
Backhoe Specifications
Digging force using bucket cylinder approx 7602 lbs
Digging force using dipperstick " " 4731 lbs
Digging Depth
Maxximum 144 in
2ft flat bottom 143
8ft flat bottom 127.6
Just some info I found on the back of the brochure.
Hope this helps
curtisfarmer said:
Builder said:I tend to agree. I would think that a enclosed cab might help sell more of them, but since it might take a CDL to pull it in some states, might as well go with a Deere 310 SG, Case 580M, Cat 420, etc and get double the FEL lift capacity, more BH power & dig depth, and 30 more HP.
Would make a nice small to medium digging set-up along with a GMC 44500/5500 dump and a 14K trailer though.
